Question about SIM2 SDV100 projector lamp Projector Lamp
Sim2 Seleco DLP SDV 100 Projector only giving white screen dimly.
Neeeeed help!!!!! Church project---Have tried many things but willing to listen to all ideas. Seems either projector isn't getting signal from computer. Older model IBM laptop thinkpad connecting to projector via an adaptor from EVC to VGA ports or cables. Manual calls for EVC but we only have cable marked PVC---is there any difference???? Adapter has ports for monitor, mouse and audio. We can see that monitor worked but haven't seemed to get sound or picture to be recognized by projector. All ideas welcome!!!! Thank you in advance for all your help!!!!
  • 2,237 Answers
It's a resolution issue. make sure the projector matches the laptop's resolution. the projector has a 800x600 native and a 1024x768 max. and it's not digital.
Posted on Aug 19, 2009
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
Looking for manuals
Hi molyneaux,
You can download the manual for free here - http://office.manualsonline.com/np/usermanuals/mfg/sim_2_usa_inc/ht300_plus__data_projector
Jul 21, 2010 | SIM2 Seleco Grand Cinema HT300 Plus...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Optoma EP719 settings?Colorwheel? Bulb?? Cable?
take the lamp out and shake the projector gently and tilt it in all directions and listen for something loose near the front of the projector. if you hear something it could be the light tunnel has collasped or the colowheel has lost its segments.
May 21, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
My optoma is projecting white spots onto the screen. They seem to just appear. Some have began by 'sparkling' for a while and then they stay white perminantly.
if it is a DLP projector then the DMD on the engine is likely bad or the main board is bad. The white things are pixels.
May 10, 2010 | Office Equipment & Supplies
We have a Toshiba multimedia projector. Model #TDP-S8. Use app. 3 hours weekly for church services. Three weeks ago, started with changing color. White looked lavendar/gray, etc. Now it consistently has a...
it needs a good service .all that needs to be done is open the top cover, the main board , clean all the dust possible.there is a glass dlp , clean it with a soft cloth ( like the one used to clean specks).on refiiting the main board make sure to firmly press the 100 pin black connector on the dlp board engine.this is the cause of the vertical flashy line
once repacked start the unit.it should work fine!!!!
Jan 10, 2009 | Office Equipment & Supplies
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Trying to update Firmware on a Sim2 HT300
Take it to an Authorised SIM2 service agent . Some things are just not for the DIY
Dec 19, 2008 | SIM2 HT300 Multimedia Projector
320 people viewed this question
Top SIM2 Office Equipment & Supplies Experts
jasbo
jasbo
Jerry Umali
Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
