Question about Goldstar MV-1526 Microwave Oven
Micro does not heat
Lights are on keypad ok, turntable ok, but does not heat
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.http://www.microwavedisplay.com/mwd_ad_a...
    What is the model number?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • Goldstar Master
  • 19,396 Answers
Est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
Replace keypad microwave pvm1870
You could probably replace the keypad yourself, as it most likely plugs in. Get the exact part number and have a search for it.
Dec 12, 2014 | In Microwave Ovens
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Mistral microwave MUMW23SS has no heat, light comes on, turntable operates OK, tested the megatron and reading 0.4 ohms, tested the internal fuse this is OK any suggestions
The keypad control board is more than likely the problem, if microwave is less than 7 years old the inverter board has been a source of trouble from time to time. When you consider parts cost it will approach if not exceed the value of a new microwave oven.
Apr 07, 2012 | Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Samsung microwave oven turntable doesn't turn now. Is it ok to still use to heat/cook food ? What is the problem with it ?
Yes it just will not cook or defrost very evenly. It is not dangerous however.
Probably the motor or gears that make the turntable go are worn or burnt out.
May 01, 2009 | Samsung MU3250W Microwave Oven
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
91 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
