Question about Kenmore 24 in. 15689 Built-in Dishwasher
Is there a way to clean the machine using the computerized controls
  • 117 Answers
Just run a regular cycle with white vinegar in a cup with the dishwasher empty.
http://tclaundryrepair.com/dishwasher
Posted on Mar 02, 2009
Why machine sewing run so slow
If it's an older mechanical machine (not computerized), it very likely needs a thorough cleaning and oiling.
Wheel on right side that controls the needle up and down is very tight...
Aug 31, 2017 | Sewing Machines
Pfaff 297-1 sewing machine runs very slow.
Your machine appears to be mechanical, not computerized. If so, more than likely your machine needs a thorough cleaning and oiling.
Might be best to take it for a standard service.
If you have the patience and time, you can try fixing it yourself. Consult your owner's manual, clean as instructed, and using Fresh good quality sewing machine oil, apply 1-2 drops as directed.
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 27, 2015 | Sewing Machines
How do you oil the singer xl.1000
You should never oil a computerized (electronic) sewing machine. You do need to clean the lint from it at intervals. Singer has the instruction manual available on their support site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/8332a66e46ddc22f7bc62f0139bf8fbd03c55b23.pdf . See page 113 (114 of the PDF) for the cleaning information.
I hope this helps.
(I have used mechanical sewing machines which need regular oiling and greasing. The computerized systems are pre-lubricated at the factory and that lubrication should last the machine's lifetime.)
Mar 02, 2015 | Singer Sewing Machines
The wheel is completely stck and will not turn. I was sewing and everything was fine and then all of sudden this happened...i took apart and cleaned....can't figure it out.
Check the top shaft bearings. Have similar problem on another computerized model. Top right bearing was completely stuck. Using Liquid Wrench to unfreeze it. Afterwards use sintered bearing oil like Tri-Flow to lubricate bearing.
Mar 11, 2011 | Brother SE-270D Computerized Sewing...
I have a Janome Magnolia 7330. How do you open it up to clean and oil it?
If it is computerized, they are generally sealed so they cannot be opened by the user. There are computerized components that could easily be damaged. The manual should have instructions how to maintain your machine. AVOID using compressed air as it tends to push lint and dirt further into the machine where only a technician can clean.
Dec 16, 2010 | Janome Magnolia 7330 Sewing Machine
Janome 6500
Under the cover of your machine where the feet are stored, on the right side,front of your machine is a round button which controls the brightness of your display. It was probably moved during cleaning.
sewman7
Aug 09, 2008 | Janome Memory Craft 9000 Computerized...
Izek Speed Control
Have you tried removing the batteries and cartridge and re-intalling? Also I learned the pressure foot must be down for my izek to accept setting changes. Hope this helps.
May 27, 2008 | Singer Izek Computerized Sewing Machine
Kenmore 24 in. 15689 Built-in Dishwasher Logo
48 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
