Question about Onkyo HTR500 Receiver
Power on but no tuning or sound from other sources
My HT-R500 turns on, and I hear the speaker relays click on, but the receiver doesn't lock on a station, and when I connect an external source and select that input, I get no sound from anything. Any ideas?
  • 57 Answers
Check for "Tape Monitor On" button. According to Onkyo's web page "Press and hold the tape button for two seconds allows the tape and MD sources to be switched - Also try the speaker A/B switch. - Check back for further assistance - The web page for your operations manual can be found at...
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
Then select your model.
Hope this helps
Len
Posted on Mar 02, 2009
No sound from center speaker or subwoofer on HT-R500 av receiver
Take a left or right speaker that you know works and connect it to the center and test. Repeat for the sub.
Are you sure you setup the AVR correctly that it knows you have a center and sub?
Aug 16, 2014 | Audio Players & Recorders
I have an Onkyo AV Receiver HT-R500 and when I turn it on, it turns on and in less than one second it turns back to standby. What could be wrong?.
Try disconnecting all the speakers and see if it does the same thing. If it doesn't, connect speakers again one at a time to find out which one of them is doing it. Make sure the speakers rating match the output of the amp.
Jun 16, 2011 | Onkyo HTR500 Receiver
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Jul 14, 2009 | Onkyo HTR500 Receiver
JVC RX-9010VBK receiver - premap section won't turn on normally
It sound like a bad connection. The first thing that I would do is tighten all the ground screws that hold the circiut boards and the heat sink to the chassis. If that doen't fix it, flex the circuit boards slighty to see if the relays chick on and off (disconnect the speakers first). It could be on the input board, on the relays themselves or just about anywhere.
Feb 01, 2009 | JVC RX-9010V Receiver
Connecting TV and DVD for surround sound
HDMI is fantastic in that's the only thing you need to plug in to get what you want.
You'll need two of them however. Plug one end of the HDMI cord into the HDMI "OUT" on the dvd player and the other end of it to the receiver..labeled HDMI 'IN' Then, take the second cord and do that step with the receiver back to your big screen...HDMI OUT to IN.
Surround sound from TV sources only needs a L&R audio cable connected to the receiver input labled TV or MONITOR audio IN. Unless you'd like 5.1 dolby digital or DTS from the television that requires devices that you haven't mentioned owning. In that case you will be able to get Dolby ProLogic and Pro Logic II from stereo broad casted sources on your TV.
Jan 21, 2009 | Onkyo HTR500 Receiver
I have a onkyo HT-R500 receiver and it keeps blowing fuses.
A receiver that recent usually has a detect circuit that keeps the outputs off until speakers are connected . So, if it bows fuses right away , it's really a power supply issue.
Probably the AC rectifier bridge.
Tech service only.
Dec 27, 2008 | Onkyo HTR500 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Onkyo HTR500 Receiver Logo
182 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
