Question about Lexmark X5470 All-In-One InkJet Printer
My lexmark x5340 will not print usb cord connected and has power.
Printed one sheet then well not print.
Mine done the same spoke to a couple of independant pc repair guys and they both said that lexmark rushed there products out instead of waiting to make sure there printers worked so i gave printer to a friend on xp and bought a cannon which worked first time and everytime
Posted on Mar 03, 2009
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
How can I fix printing hesitation on my lexmark x5495
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 16, 2012 | Lexmark X5495 Printer
Printer will not print
If unplugging and re-plugging the printer into your computer doesn't help, try the steps below:
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
My lexmark x1270 has power,but will not print from the pc
  4. Reboot computer.
Oct 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer will not print. Removed both print cartrages, replaced black only due to cost/need. Printer will still not print (sheet comes thru blank)
Make sure both color and black cartridges are installed in the printer. The printer requires all cartridges to have ink in them to continue printing.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark x63 and everytime i try to print something it says the device is busy try again later. i click on the printing icon that pops up in the bottom right hand corner of my screen and there is...
hi Cavschick104.
this is all i could find out.
COMPLETELY uninstall the printer and
reinstall it..... It may have occurred if you have your printer connected
during the installation of XP.... it is normal practice to keep the printer
disconnected during an upgrade or clean install.... and then correctly
install it afterwards.
This from the Lexmark site:
Remove the USB cord and the power cord from the back of the printer, and then remove
the USB cord from the back of the computer.
Uninstall the printer/scanner software from the Program menu and restart the system.
Check the part number on the setup CD. If it is not P/N 13H0350, you need to download
the XP driver from the Lexmark web site, www.lexmark.com.
When the PC has restarted, log in as an administrator and insert the setup CD into
the CD-ROM drive
Click OK and Install now.
Follow the setup instructions to install the scanner software. When you see Connect
the USB Cable to the printer on the screen, first attach the power cord to the
printer, then attach the USB cord to the printer, and finally attach the USB cord to
the computer.
Follow the setup instructions on the screen to complete the printer software
installation.
If you want technical support of Lexmark, you can contact us on Lexmark Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/bpBgcR
Lexmark Printer 1 866 877 0191 Help Support Service...
Nov 27, 2017 | Lexmark X63 InkJet Printer
Lexmark x5340 refill assistance needed
I would like to inform you that Lexmark does not support refilled cartridges and if you use refilled cartrdiges then it will harm the print head in the printer. Use genuine Lexmark original cartridges.
Apr 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5340 printer "can't communicate with computer." All hardware okay. Just bought new USB cord since printers don't come with them anymore. Have older computer 2001 Gateway, however was wondering if...
I had a brand new usb cord that didn't work but cost a lot of money. I went to wal-mart and bought a usb cord for like $6 that had a printer icon on the package and hooked that up and the message disappeared. I don't know if that helps but hope it does.
Mar 09, 2009 | Lexmark X5470 All-In-One InkJet Printer
My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
hi
follow these steps
1.checked for and remove any obstructionsfrom paper feed tray.
2.tilt and shake printer..checked for any rattling noise..checked for any foreign objects inside printer obstructing the paper flow.
3.Take a sheet of paper ..fold it length wise 3-4 times to make it a thick.insert this into paper feed tray...move it left and right a couple of times..unplug power cable and replug it after 10 seconds...try printing ...if it does not work,,,,contact tech support 1-800-332-4120...ur printer is brand new and under warranty cover,,,they would replace it for u.
goodluck:))))
Jan 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
