Question about Frigidaire FEQ332E Electric Dryer
My dryer was running fine, and all of a sudden it cut off, and want come back on
  • weyum Apr 19, 2009
    Grannynettle, I have the same problem. Does your machine make a buzz sound when you try to turn it on after it stops. I have to turn the drum by hand and then it will start again. I have changed the front felt glide and greased the rear drum bearing, thinking that there was too much stress on the motor. The problem is getting worse though.
    Trydisndat, any Idea of what it could be
    Thanks
  • 686 Answers
Thermal fuse may have gone bad. When this fuse goes bad your dryer may not come on at all or just the heat element in your case i'd check for an open thermal fuse. Then we ca go from there. By the way if you keep stuff on top of it such as clothes take them off and don't store anything on top. Store clothes on top ot it will cause it to over-heat and thermal fuse damage is the result
Posted on Mar 02, 2009
  • BmanMA Oct 14, 2010
    I have the same problem, and after ohming out the thermal limiter, it looks fine. The door light comes on and it makes the buzz. So I assume I can rule out the door and start switches.
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer keeps shutting off
If it's shutting off while it's running, it's probably the thermal overload fuse tripping and cutting off the power. This could be caused by a number of things, so if you can post back with the following information, I can assist you further more easily.
1. Your brand and model of dryer
2. Does the dryer turn back on quickly or do you have to wait about 15-30 minutes?
3. Is it making any unusual noises?
Thank you.
Oct 19, 2010 | Bosch Dryers
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
No Heat
You can do a few tests your self first cheak the breaker box on the house snap it back and forth a few times then run dryer if that does not work you can cheak the thermal cut off located on the rear of dryer .Remove the rear panel and on the right side you will see your element housing the thermal cut off is the top thermostat on the housing join the wires together and run dryer.If that does not work then you may have a bad element.
May 20, 2009 | Roper RGX4634KQ Gas Dryer
Heats & drys fine but stops running after a long period of use and won't start back up right away. I assume it is cooling down then will run again.
Your dryer vent needs to be cleaned. Also, pull out the dryer and clean the part of the vent entering into the dryer from the back. This will cause the unit to cut out on thermal lockout.
Apr 16, 2009 | Dryers
Frigidaire FEQ332E Electric Dryer Logo
240 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
