Question about Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput
Burning eyes and sore throat when heater is on
I have a reddy heater 65,000- 100,000 btu variable propane heater. It looks like it lights fine and runs good but its putting out lots of fumes that irritate my eyes and throat can this be fixed or do they all work this way
  • 362 Answers
This heater should only be used in a very well ventilated area, the sore throat and burning eyes are from carbon monoxide.
Carbon monoxide is potentially fatal.  I cannot express how dangerous this is if used in a house or garage without the doors open
Please be careful and let me know if I can provide furthur assistance.
Lone99star
Posted on Mar 02, 2009
I have a propane 155,000 btu forced air heater. when it runs the air burns my eyes
Your mixture is too rich. Go to http://www.reddyparts.com which has assistance with setting the fuel balance or get a new control valve from them.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 12, 2011 | Reddy Heater-30,000 BTU Propane Forced-Air...
Model rlp50 50,000 propane heater fan will run, will light, but won't stay lite when you release button, fan still runs
i have the exact same heater with the exact same problem. tested the thermocouple seems to be fine, tested the relay, it seems to be fine, could it be the gas valve????
Jan 12, 2011 | Reddy Heater-30-55,000 BTU Variable
My heater worked fine for a few months last year before it started burning a smaller flame and not heating as well. I then started noticing the increase of propane used. It seems as if it is running rich ...
Check for an air filter....many of these heaters have an air filter that gets dirty or clogged and then they will do just what you are describing her....
also take an air hose and blow out everything....
What you have there is an air/fuel mixture problem...
you are not getting enough air to the burner... most like because of dirt...
The only other explanation would be that the blower is no longer running at full RPM's....
You could also try to get some oil on the shaft of the motor to lubricate it and get it running back to full speed again...
Check the fan blades for dirt also...
heatman101
Nov 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
I have reddy pro 100 lp gas heater when i run it within afew minuets my eyes nose and throat burn. ia'm using a 20#cylinder the flame is pretty much blue
are you using it in a closed room? you should be using it where there is air circulation. what's happening is the heater is using up oxygen and is producing carbon monoxide which is poisonous and if you are not careful IT WILL KILL YOU!
Oct 25, 2009 | Reddy Heater RLP100 Portable Forced Air...
Ihave a R60A heater that when I turn it on it
This is in referance to the R60a 60,000 B.T.U. Multi fuel heater
Sounds like the your ignitor has burned out. Had the same problem. Now looking for a replacement. Checked mine and for some reason the filiment has broken/burned off. Ran across this on a search for one. Good luck!
Oct 11, 2009 | Reddy Heater RLP100 Portable Forced Air...
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Burning eyes, can't breathe.
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
Feb 10, 2008 | Reddy Heater RLP100 Portable Forced Air...
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput Logo
2,011 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
