Question about Maytag Washing Machines
Maytag Atlantis Washing Machine always runs warm water whether hot, warm, or cold is selected. Is there some setting that I may be missing or a part that may be faulty?
  • 117 Answers
Sounds like it may be a faulty temperature selector switch
Posted on Mar 02, 2009
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
When set to cold, it still runs hot or warm water. What part do I replace first to try to solve the problem?
Could the problem possibly be that the hoses accidentially got switched around. This would make hot water go in when it calls for cold and cold water go in when it calls for hot. A good place to start anyway.
B.C.
Jan 17, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Atlantis Mod.# MAV7600AWW doesn't come on with the cold water selected. It will come on with warm or hot water. The spin cycle seems to work ok when dialed to it. Before the washer seemed to...
the machine control opens both hot and cold water valves and then the machine sensor monitors this through a water temp sensor in the fill line till a certain amount of resistance is encountered so it could be a faulty sensor,machine control board or also if a certain type of wash is selected it wont use any cold water at all during the whole wash cycle
Mar 13, 2010 | Washing Machines
There is no cold water only hot and the machine shuts itself off before filling with water
Not enough information, but I'm assuming you have 2 inlet water valves. 1 hot water and 2 cold water. Possibly you connected the hot water to the hot water valve. It must go to the cold water valve instead. Not good to run the washing machine like that as it will bring other problems into play. (colours running, plastic distorting etc.). That's if it is very hot water.
Oct 10, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Can't get anything but warm of hot water
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold button is pressed and warm water comes out
water valves might be wired wrong or water select control is bad or wired wrong
Apr 10, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
No hot water
Make sure your hot water supply valve is on first. If so then try reversing the hot and cold water feed lines and see if you get hot water when asking for cold. The water valve for the hot water side could be bad. Are you familiar with a voltage meter or know someone that can see if you valve coil is getting 120V when the machine is trying to fill with hot water. If not the control unit is faulty. If you do have the 120Vac on the solinoid coil and no water the either the coil is open circuit(bad) or the inlet is plugged. Most generally the problem is in the control knob unit.
Feb 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
