Question about Brother MFC 6490CW InkJet Printer
I can not print
My Brother MFC-490CW is setup to be able to print wirelessly and is successfully connected to my wireless network. But when I try to print something on my laptop, which has the proper printer software installed, the printer shows up as 'offline.' and I to restarted the computer and when is string again the machin print the doc in que; but again show the printer is offline. Please I need help
juancho47
  • Anonymous Mar 31, 2014
    when I use my laptop to print, the print icon comes up but doc fails to print and I check the print que on print doc view it says error-print
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Posted on Jun 02, 2009
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
Tip
User Manual for BROTHER MFC-490CW Color Inkjet All-in-One with Wireless...
Hi guys,<br /><br />Here's an official Usermanual/ brochure for BROTHER MFC-490CW Color Inkjet All-in-One with Wireless Networking.<br /><br />Link:<br /><br /><a href="http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/MFC490_Catalog_Pages.pdf">http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/MFC490_Catalog_Pages.pdf</a><br /><br />Click on this link or copy and paste the complete link into your browser.<br /><br />If I could be of further assistance, let me know. <br /><br /><br />Thanks,<br /><br />LETMEFIXIT<br />
on Feb 08, 2011 | Brother MFC 490cw Color Inkjet...
I CAN NOT CONNECT WIRELESSLY?
My MFC-490cw connects to the wireless internet and so does my computer. However I am still unable to print, scan, etc... The status monitor claims it is offline. I recently switched routers and it seemed to cause the problem. Any ideas on a fix?
Feb 18, 2010 | Brother MFC 490cw Color Inkjet...
Can't access Brother MFC-490CW printer using D-Link 628 wireless
You will have to reset the "Path" to the printer, so the "Client" PC can find it. EG: \\MSHOME\Brothermfc, also ensure "Sharing" is enabled in Properties on "Main" PC. Also ensure you are all on the same "Workgroup" & PC's have a "Name", and the "Printer" is installed on the "Client" PC too. and you can print a test page from the clients too..
Feb 03, 2010 | Office Equipment & Supplies
Brother MFC-490CW printer Does not connect to my computer
You willl need to setup the printer first to use the wirelss in your place. Once you have that you will need to have the cd to install the printer and it should work.
DirectTech Computers
Palm Desert, Ca
Brother ASC Center
Jan 01, 2010 | Brother MFC 490cw Color Inkjet...
I have the MFC-490CW, I am trying to install it to be wireless. But I can't figure out some of the items. How do I find the WEP key?
My brother MFC490-CW is connected wirelessly to the router. It printed OK wirelessly yesterday when I set it up but today it will not print. The printer has a strong wireless connection to the router. My PC also has a strong connection to the router. But the printer seems to have lost the connection to my PC. How to I re-establish the wireless connection from the printer to my PC?
Nov 03, 2009 | Brother MFC 490cw Color Inkjet...
My printer is connected to the internet, but status is 'offline'
Hey Bud. I had the exact same issue with mine. I called around and no one had an educated answer. I remembered that my Uncle Lester works for the IP department for the city of Beaumont. I called his house and of course he was at work. Just for grins I asked his 8 year old daughter how to fix it. She simply said, "Just unplug the router and plug it back in.... What a ********...." Then she hung up... Neddless to say this seems to work for everything else too.... Good luck.
Dec 31, 2008 | Office Equipment & Supplies
Brother MFC 6490CW InkJet Printer Logo
1,278 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
