Question about Vision Cameras
Camera alignment for fabri vision scanner.Used in sheet metal shop
There is 7 or 8 camera in this unit. Need calibration standard
There are 8 CCD cameras.Before I can help I need to know what kind of machine you have FV4600 or FV4800? or machine serial number so I can cross reference? Or you can contact the following:
Angel Lee
GaugeOne International
Fabrivision Service Specialist
email: gaugeoneintl@earthlink.net
Cell Phone: 818-381-1568
Posted on May 19, 2009
How to rerair sigma 150 500
That depends on what's wrong with it.
Don't even think about taking the lens apart yourself unless you have a lens collimator and other equipment needed to ensure proper alignment on reassembly. Otherwise take it to a reputable camera shop and have a properly trained and equipped professional do it.
Nov 08, 2014 | Cameras
Prints and scan OK but printing is very poor.
Run the printer through the head cleaning cycle and then print a test sheet to see if you get the proper pattern. You may have to do this several times. If the printer is seldom used the head nozzles get clogged. There is also a calibration cycle and that is used if the lines don't line up properly.It's in the manual or can be obtained from Epson online.
Aug 30, 2014 | Epson PX730WD Stylus Photo
Need to clean my minolta 75-300mm internally
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, take the lens to a reputable camera shop and have a properly trained and equipped professional do the cleaning.
Mar 10, 2014 | Minolta 28-80 AF Lens
How to clean the fungus off a Mirror on the inside of a 500mm Mirror lens
Unless you have a lens collimator and other gear needed to make sure you get the lens and mirrors aligned properly when you put it back together, don't even think about taking it apart. Take it to a reputable camera shop and have a trained professional do it.
Jan 30, 2013 | Samyang 500mm f8 Ultra Telephoto Manual...
I JUST got a Nikon Cool Pix L22 but no matter what setting I use EVERY picture is blurry. I am an art teacher and understand shutter speed and aperture, I even used a tripod. The pictures are still...
Most likely your fisheye lens attachment is out of alignment. An internal element may have come unscrewed or unglued. The other option (I'm assuming you have already checked this) is that it is incorrectly attached to the camera - check your threads and make sure it wasn't cross threaded and that there are no blockages to the lens attachment being screwed in completely. If the fisheye lens is not in the correct position relative to the CoolPix lens, then the pictures will be blurry.
Nov 21, 2010 | Opteka Full Fisheye Lens for Nikon Coolpix...
I have a sigma 18-35. It has not been used in a while and mold has formed on the inside of the lens. How can I open it up to clean?
Hi
to remove the front lens you will see a ring that you can peel off and you will see
4 screws take them off and the front lens will come off
Oct 12, 2010 | Sigma 18-35mm f/3.5-4.5 Lens
Water spot in lens
Unless you have a lens collimator and other equipment needed to ensure proper alignment when putting the lens back together, take the lens to a reputable camera shop and have a trained professional do it.
Jul 15, 2010 | Tamron 28-300mm f/3.5-6.3 Minolta Mount...
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Tokina Zoom Lens
read this you will,automatically come to know
MINOLTA 16mm CAMERAS From their modest beginnings after World War Two, the Minolta subminiature format rose to become the most popular Japanese 16mm, still-picture manufacturer and helped Minolta establish itself as a major player in the photographic industry. The revolutionary Minolta cassette is the closest the subminiature market ever came to a "standard" 16mm film format and it was copied by many other camera companies, even outside of Japan. With the exception of the Minox cassette, it is the long-distance runner of the submini world; Minolta manufactured and sold its film cassettes until 1995, and replicas are still being made in the Ukraine and China (?), today. Fortunately, even the older cameras are still very useable since the Minolta cassette used 16mm film (which is still readily available), and they did not require perforations in the film to advance the film. They are very easy to reload. Check out The Darkroom for details.
The original Minolta 16mm camera was designed by the Konan Institute and used the original Konan cassette. This cassette will not fit in any of the Minolta cameras -- or at least cameras with the Minolta name, since Minolta ended up making many cameras with the Konan name. Basically, Minolta bought-out Konan. When Minolta took over, they redesigned the cassette using black felt for the light trap. There were actually several versions, nearly identical. The first was metal, but this was soon replaced with the more standard plastic type -- of which there were several versions. Minolta made two plastic models, identical except that on the second version a notch or indentation was cut into the cassette bridge to make it easier to break off the film take-up lobe for processing purposes. (If you have the newer version it's a good idea to fill in the notch with a little epoxy to make it last longer.) To complicate matters even more, similar cassettes were made by other companies, such as Yashica (which sold a camera that used the Minolta cassette), a company called FR (which sold the film and offered processing), and others. The Minolta cassettes are fairly easy to find today, and will fit in all of the cameras on this list. They will NOT fit in Mica and Konan.cameras. To top it all off, there are even bogus Minolta cassettes being sold. For more information check out the NEWSTAND.
May 24, 2008 | Cameras
Cameras Logo
408 people viewed this question
Top Vision Cameras Experts
Are you a Vision Camera Expert? Answer questions, earn points and help others
