Question about Kenmore 62872 Electric Dryer
Very loud squeaky noise on Kenmore dryer model 417.80042990. Seems like it's coming from the back. Is there a way to lubricate it?
  • kjmcclure Mar 21, 2009
    I have the same problem with a Kenmore electric dryer model 417.81142000 - will the same fix work?
  • 686 Answers
Yes there is you'll have to get high temp lubricant or grease. Here is how to get to it. first check this site out to help you see and recognize the parts www.repairclinic.com/Appliance-Parts?s=t-41780042990-%3d%3d&z=100 Check out items 1851 and 774936. This is were you need to get to. First remove small access panel on rear after unplugging from power source of course. Reach in and undo belt. Then look at the very bottom of your front panel if you see two screws lay the dryer down on it's back and remove the screws. Lift the bottom a bit to see door switch wires undo them and remove front panel it will hook in at the top under the main top. Then unscrew the 3 screws inside the drum in the middle and pull drum out. note the 2 items I have given you item 1851 slides out of the cup(774936) apply high temp grease and replace item 1851 and put it back together. If you don't have the 2 screws at the very bottom of the front panel for removing then the other way to open it is by prying the main top up with a wide flat screw driver toward edges between main top and front panel then removing 2 screws on the inside of the front panel toward top then unhooking at bottom. To facilitate belt replacement I use small scotch tape pieces to tape the belt to the drum so that when you have it back together and you re-stand the dryer you can reach in from the rear access panel to re-attach belt to motor and tensioner. If this scares you too much you may call me and i would be glad to walk you through it. My name is James 417-926-0106. I hope these directions help and you have a successful fix. This type of problem is very simple. Do not forget to re-connect your door switch wires or it won't run at all. Good Luck
Posted on Mar 02, 2009
    Problem Solver:
  • 5 Answers
Look at back and get model number and search google how to replace bearing. Go to utube and search replace dryer bearings on different models. Very easy to take apart, if you use dolly and cart it into a large room. Anyways, take apart and GREASE bearing. Use high temp grease if you can, maybe the car break grease would be acceptable, small pack very cheap. Should not need to replace bearing but if you do, order part online, not much $$. Ask your neighbor to do this for you, if you can not. Not need a special repair person for this task, beleive me.
Posted on Feb 15, 2012
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
When we start the dryer it's stsrt making loud noise matal to metal then it goes away for few minutes and comes back
Hi bojanhadziki...
You could have a couple of problems..
1...The door seal may need replacing, making metal to metal contact
2...The drum rollers may need lubrication or replacement
3...The back bearing may need replacement or lubrication.
Please take time to rate me
Sep 26, 2011 | Kenmore Elite HE4 Electric Dryer
We have a loud squeaky noise coming from what seems the back of the dryer on the left side while the drum is spinning. The model number of the kenmore dryer is 11087562601. We cleaned out the vent system....
Hi chazt3
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Jun 27, 2011 | Dryers
Kenmore HE4 dryer is making loud noise, like a shoe is in it. The back bottom roller appears to be very loose. How to tighten?
Your problem sounds like drum rollers have flat spots on them .
or wear on them replace them.
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
Kenmore model 158.17810 sewing machine noise
that is a fifty fifty chance you have to take. It may be something minor rubbing or you could have a slightly bent shaft underneath making noise
Dec 10, 2009 | Kenmore Sewing Machines
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
My dryer is making a very loud squeaky noise. Is is the motor or something else?
Not the motor if it's still working. The noise is coming from the bushing that hold the drum in place.
Apr 05, 2009 | Maytag Dryers
Kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Mar 06, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62872 Electric Dryer Logo
1,186 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
