Question about Microsoft Xbox 360 Console
Green toggle lights
I turn on one controller and the top two green lights on the ring toggle back and forth. it doesn't seem to pose any problems, yet! just wondering if there's a problem or if one is on it's way.
    Problem Solver:
  • 16 Answers
When the lights blink it generally means that the xbox controller is losing power. try charging it or replacing the batteries
Posted on Mar 03, 2009
Epson Stylus Photo R2400 does not start up.
That sounds like the main control board is faulty.
Use Epson.Co.(your country) to find some local service agents, describe those symptoms to them and compare their answers.
Sep 22, 2016 | Epson Stylus Photo R2400 InkJet Printer
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Can I get rid of the date from my pictures?
To turn on or off the Date and Time stamp features, push the menu button. It's the small silver button on the back panel directly beneath the printed letter M, and just above the little green LED. This opens the menu. Now, press the right side of the ring shaped control button, where the little lightning arrow is. This will scroll through the different menu categories. Keep scrolling until you get to the one at the far right of the screen. It is a blue icon that looks like an envelope and a clock. This will bring up the menu for toggling the Date and Time stamp. Use the top and bottom of the ring to select the setting you want, and press the button in the middle of the ring, marked SET DISP, to select it. Then press the menu button again to get out of the menu and return to taking pictures.
Jan 20, 2011 | Polaroid i830 Digital Camera
Regarding my Raypak Spa Heater Versa 055B: Burner comes on but after approx 1 hr, shuts down. At first I thought was toggle switch. I ended up replacing it a few times, each time I thought problem was...
I'm assuming, first, that your pump is running when you turn up the temp, otherwise, the high temp switch will turn off the gas. Then, it could be any of the switches hooked in series that must have flow thru them to let yhe ignition open the gas valve. ie could be water-flow switch not sensing enough eater running by it. Bypass (jumper) one at a time to find the culprit. Good luck...
Oct 19, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Kenomore ultra wash dishwasher will not clean dishes- water pump may be out? How do I perform self diagnostic test?
check and see if both wash arms are turning first.
does the lower arm turn but the top arm does not?
Another way to check to see if your upper wash arm is turning is to put a mug in the top rack upright. close the door and turn the dishwasher on if it fills the mug within 2 minutes you are getting proper curculation.
you press heated dry and high temp wash and toggle back and forth within 6-8 second. all the lights should light up and it will go into diagnostics.
Sep 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Orange LED indicator on the "Power Ring"
From the sounds of things you have a bad RF Board. This is the board that controls the syncing of your controllers, as well as your ring of light. If there is someone in your area that fixes the RROD they may be able to replace your RF board as well. I'd be happy to do it, but shipping would be almost the same cost as the repair. Contact me at Jordan@jordanselectronics.com for more info.
Jan 09, 2010 | Microsoft Xbox 360 Console
How to Bypass E-Brake Screen For In Dash DVD Player?
There should be a green wire if not the wire that states to hook to the e-brake hook to a hot 12v source and that should fix the problem. You may have to ground that wire instead depending on the model.
May 22, 2009 | Clarion VRX485VD Car DVD Player
Xbox turns on but i have no green lights
What appears to be the problem in my case is that the RF module board in which the power button and the controller sync lies has been damaged. If aboslutely no lights come on when you power on your xbox 360, but it loads like normal, something has fried on the module and needs to be replaced. You can ether contact microsoft about this, or buy one off of ebay and install it yourself or have someone who knows how install it for you. Doing so would void your warrenty of course though.
Dec 10, 2008 | Microsoft Xbox 360 Console
Wireless controller
I dont know if you have been able to figure out what the proble was with your 360, but the exact SAME thing happened to me. The 360 seems to be working fine, game loads, and both the consoles and the controllers rings lit up green, but then the controllers ring just keeps flashing and the console won't recognize it. I 've tried other controllers and nothing worked and obviously I tried to synch it with the console time and time again. PLEASE HELP!!!
Apr 03, 2008 | Microsoft Xbox 360 Console
Green clean light flashing dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
Nov 22, 2007 | Dishwashers
Microsoft Xbox 360 Console Logo
49 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
