Question about Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion
Cordless Dremel variable speed stuck on maximum
I have a cordless Dremel with variable speed control but when i switch it on it goes straight to maximum speed and i cant turn it down. I guess its just a variable resistor but does anybody know where i can get it fixed? I am based in South London
Thanks
  • eeweh Mar 21, 2009
    Variable speed model - now runs only at full speed or off - variable function failed. About 6 months old. Also 3 x LED to show charge also not working now... Fault after using for about 3 mins - dremel got hot (no cooling fan in design?) so I presume it's overheated itself? Every other drill has a fan for cooling.
  • Anonymous Apr 30, 2009
    Same problem here with variable speed ...I ended up replacing the variable speed unit and it was ok for a year till it craped out AGAIN :(
  • 257 Answers
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Posted on Mar 02, 2009
When I press the power switch it starts to work at maximum rpm
The variable speed function is controlled by the switch. On rare occasions you can remove the switch, spray it with electronics cleaner and blow it out well to get it to work again. Usually you have to replace the switch. The switch for your impact driver is Makita part number 638326-6 and runs about $65.
Jun 08, 2012 | Makita 6980FDWDE 12V Cordless Impact...
Hi, my cordless dremel 10.8v does not switch on beyond switch no. 2. Please help. Thanks.
The switch is defective or the brushes.But replace both.Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Dremel Variable - Speed Multipro Rotary...
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only...
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Nov 06, 2010 | Dremel 8000 01 Cordless Rotary Tool Kit...
Where can i find an instruction manual for the clarke ct4009 rotary tool
i have a dremel cordless rotary tool but have no manual,if anyone has one for the Dremel Lithium-ion cordless 10.8 variable 5,000-35,000 rpm model 800,can you kindly email it or tell me where to download it from at
rkellock@eastlink.ca
thanks "R"
Jul 08, 2009 | Tools & Hardware - Others
Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
I need a coupling
Call Dremel at 1-800-275-2052 and they can help with parts and schematicsHope this helps. Dave
Nov 08, 2008 | Dremel Variable - Speed Multipro Rotary...
New dremel
It was just retired there is nothing recalled its just an old model
Oct 17, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Cut out tool Comparison
Cut out tools are available in both cordless and corded versions. Cordless tools can be more convenient. The corded versions are slightly more powerful than cordless.
Aug 27, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel Scroll Station 1800
You need to replace the variable speed control switch. Other than that, your not doing anything wrong. Have fun
Feb 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion Logo
1,079 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
