Question about Siemens Computers & Internet
Do you need a disc to hook the modem up - Siemens Computers & Internet
  • 15,935 Answers
Your non-specific question is hard to answer without all the facts... but generally, any O/S above Windows 2000 will have the necessary drivers.
Depending how new your router is, you may need a driver download from Siemen's website for whatever O/S you are using.
As a general rule, once installed (with a disc) you should go to the site for the latest drivers anyway.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 02, 2009
How to hook up dsl
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope it helps you
Mar 20, 2012 | Compaq Presario 5222 PC Desktop
Sb5120
1.screw the cable line into the (F-connector)port in the back of the modem just like a tv does.2.then use the RJ-45 lan cable supplied with the modem,plug it into the RJ-45 port in the back of the modem.3.then plug the other end of the cable into the computers RJ-45 port.4.then power on the modem by pluging it in,and letting it boot and detect the internet signal and all lights are on and in working order.then start surfing.The only time you will need the install cd is if you need to use the usb hook up on the modem.
Jan 31, 2012 | Arris SURFboard SB5120 Modem
When I hook up this router I can't get online when I go right to my motorola modem for comcast if works fine but I need the extra security. Do I need to download and drivers for this a manual may help.
With all routers you need to follow the instructions on the setup disc in order to get the router to work. The program contained on the disc will program your router to work correctly.
Mar 22, 2011 | Computers & Internet
I just got a surfboard sbg901 couldn't lind it listed. My computer refuses to take the startup disc. Says it has a trojan and shuts down. I hooked the modem up an dit works fine. I cannot go wireless...
If you are booting from your OS disc, there will be no system loaded and certainly no anti virus loaded so it is not likely it is loading from the start up disc. Ensure the BIOS is set to boot from your start up disc first.
Oct 13, 2017 | Arris SURFboard SBG900 (49402201900) Modem
I lost my disc to set up my wireless router in my computer and i already had it in but some how got deleted or lost cant find how do i hook it back up...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Oct 23, 2010 | Belkin (F5D8231-4) Wireless Router...
How to hook it up to computer
alright man routers are easy look you need to have a MODEM!! INternet MODEM.. that has a LAN LINE or cord
1. connect your modem LAN line to the router, the router MUST have a HUB where you can plug it in the router hub it should say LAN connect it there!!
2. connect the ethernet cable that came with your router ,connect the ethernet cable to the router on the hub that says 1 connect it and the other side connect it to your computer!!.
3. now insert your disc that came with your router!
adjust your router settings!! allow wi-fi if available and put your password!!
4. your router is set!!
thank you i hope this helped you!! leave a testimonial!!
Aug 02, 2010 | NetGear WGT624 Wireless Router
Lost the disc to run the router, is there anything I can do?
unplug and replug the cable modem and the router. You don't need the setup disc just type the ip address of the router into your browser. most dlinks are 192.168.0.1 and password is admin (unless you changed it). For a cable modem you want it set to DHCP configuration.
May 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My wifi got disconnected along with my dell control point and I can not get on the internet on my laptop and my linksys router has the blue lights going but I can not hook up my laptop to it and I can not...
May 02, 2010 | Linksys WRT160N Wireless Router
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Mar 03, 2010 | NetGear WGR614 Wireless Router
Lost disc
hi there i went to the westell site and downloaded the drivers for mine try it if not there use the google search enging for the the device ok best regards mike
Feb 18, 2009 | Westell Wirespeed LiteLine 6110 Modem
Computers & Internet Logo
56 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
