Question about Lexmark X4270 All-In-One InkJet Printer
Error Message My lexmark screen has a error message 1200. How do I correct that?
  • 15,935 Answers
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 02, 2009
  • blueextc3221
    blueextc3221 Mar 02, 2009
    ALSO...
    CLICK HERE
    for a few more troubleshooting techniques that are covered under the error 1200.
  • 2,404 Answers
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.
Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.
I have an error 1200 on my screen
The 1200 error code indicates that the cartridge carrier has stalled. Please refer to this article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to fix the issue.
Aug 30, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Error 1200 is showing
The 1200 error could be caused by a cartridge not properly inserted in the carrier, encoder strip got unseated from its position or there's something blocking the cartridge carrier path. Try to refer to this article in the Lexmark website to determine what's causing this and resolve the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
May 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have done solution 1 to get cartrage moving, but printer still error # 1200,what else can i try?
The "1200" error message can be caused either by the cartridges that are not snapped in correctly, the encoder strip (transparent strip) is not in its position or something is blocking the cartridge carrier path. Please refer to this article in the Lexmark website on 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Feb 24, 2011 | Lexmark X4250 All-In-One InkJet Printer
How do I fix error #1200
Please refer to this article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. This article will help you identify and resolve the problem. But if problem continues, please contact Lexmark technical support. Thanks.
Dec 12, 2010 | Lexmark X4270 All-In-One InkJet Printer
We are not able to send faxes,the error message is 1200. The reference number for the fax is x4270.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error code *1200
Please refer to this article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the issue. If error continues, please contact Lexmark technical support for further troubleshooting. Thanks.
Nov 17, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer keeps popping up Error 1200 on The lexmark x4270
The 1200 error code indicates that the cartridge carrier has stalled. Refer to this article 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One on how to troubleshoot this problem. If error continues after going through the steps, I would suggest you contact Lexmark technical support so they can further look into this issue. Thanks.
Nov 09, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
