Question about Samsung DLP HL-P5663W 56" TV
I have a Samsung DLP 50" r5067w that is acting weird. When I attemp to play a DVD/CD the screen has flickering bars running across it. I can bearly see the actual DVD in the background and the sound is great. I have unplugged it for approx. 5 mins and that worked for a while. Now, there seems no cure for this issue. If I'm watching cable the picture is fine, although I now experience an occasionally resetting of the set as is pwr off and then back on at random times. v/r, QSligh
  • 1 more comment
  • quentinsligh Mar 02, 2009
    For further clariforcation, I'd like to add the following:
    The problem is with both my WII as well as my DVD/VCR player which both have been working for over 2 years. This issue started 2 months ago. I have uplugged both and reconnected with no luck. Simply unplugging the power from the TV and waiting for approx. 5-10 mins use to work, but now that is a hopeless fix. I have changed my AV ports, ie. used AV1, 2. and 3 and still no such luck.
    My connections are as follows:
    Onkyo 7-1 surround system
    Verizon HD/DVR
    connected via HDMI to TV from HD/DVR
    Thanks Ronnieh49,
    Are you suggesting that there is not plausiable fix within my realm other than a costly visit to the repair shop? If that is my only option, then I must weigh my ROI for this TV. As with a doctor's opinion, I'm always open for other suggestions.
  • 3,037 Answers
Horizontal bars? It sounds like the digital board is the culprit as these tvs had a few problems. The good news is the company wants to retain customers so call 1-800-SAMSUNG prompts 2, 1, 3, 1 and be very persistent. Get past the first levels and explain the situation. You wouldn't be the first person out of warranty to be offered a newer model for the cost of shipping with their company, otherwise unless you are electronically skilled, your best bet is to take it to a shop to get diagnosed for sure on what the problem is as it may be a couple other things too but the digital board is the best bet from your description.
Benjamin
Posted on Mar 02, 2009
  • 82 Answers
Try to press these buttons
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
    Novelist:
  • 148 Answers
Check the cabling between the DVD player and the screen first. Next make sure that both the DLP50 and the DVD player are not in confined spaces where air flow is blocked. This could be a heat issue, too. Im banking the "working after unplugged for 5 min" to heat. How long have you had the DLP 50?
  • 1,800 Answers
Hello sir.
the problemis related to the AV IC parallel .
A capacitor was warming up every time, this time its blown u shud replace it .
a soledring skills and hot air is required!!
plz just use our repair stores guide and locate the nears tech to u and i do advise u to do not take the risk of taking apart the unit cuz u would cause much more damage and u might get electrecuted!!
    Genius:
  • 2,920 Answers
If its really a nice tv id take it in and have it repaired before it can get any worse than it is now.i dont know what the cost would be but if you feel the tv i worth it id take it in as soon as i could and get it repaired
  • 564 Answers
Thanks for Choosing FixYa!!!
It seems to be problem with the DVD Player and not with the TV.
Unplug the DVD cable from the TV and try connecting it back again.
Hope this Helps!!! Please rate my Response!!!
Thanks!!
PREM
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
I have a Samsung DLP HL-R5067W that works great with HDMI as the source but flickers five lime green/purple vertical stripes when using the video/ audio input jacks. Thoughts?
those units have had problems with the siganl board and dm module both having solder connection problems and require to be sent out to a rebuilder that can handle that special work you might call samsung consumer and see if its uner and class actions or recalls
other wise it will be a local servicer to assist you further with its problems
Jun 05, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
Aug 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Samsung HL-R5067W DLP HDTV. I have HD cable from Comcast. My TV plays the HD signal flawlessly. The non HD channels have columns and rows of colors on the screen. The picture can sort of be made...
this could be 1 of 2 things--either the light engine or the digital board--i'm betting on the board because hd cable is good--light eng/cost prohibitve--board maybe !!
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
People are green
Your color wheel is not turning. This is part of the light engine assembly which is the section the bulb is insalled into. Usually the whole assembly is replaced.
Mar 23, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Fault with the picture of a Samsung television
You appear to have a DMD failure part# BP96-00249A with a list price of about $622.00.This is a common failure with Samsung DLP type televisions.
Jan 14, 2009 | Samsung HLN5065W 50" Rear Projection...
Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Dec 14, 2008 | Samsung 50" Slim-Depth DLP HDTV
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
20 people viewed this question
Henry  Thomas
Henry Thomas
