Question about ASUS Computers & Internet
My motherboard will not accept anymore than 512 megs of ram what can i do to fix this thanks DAN
  • 1 more comment
  • dfrommotown Mar 03, 2009
    YOU ARE ON TO SOMETHING AND THE REASON I SAY THIS IS BECAUSE MY FRIEND SHOWED ME A WEBSITE ASUS TEK.COM AND IT GAVE ME ALOT OF INFORMATION I HAVE FOUND OUT THE INFORMATION I NEED . THANKYOU FOR TAKING THE TIME TO ANSWER MY QUESTION IF ANYONE ELSE HAS A QUESTION ABOUT ASUS BOARDS SEND THEM TO THIS SITE. ASUS TEK.COM
    DAN FROM
    CALIFORNIA
    IT IS A A7 BOARD.I FOUND A WEBSITE ASUS TEK.COM THAT HAS GIVEN ME ALL THE INFORMATION I NEED BUT I THANKYOU FOR GIVING ME YOUR TIME AND INFORMATION
    I DIDNT KNOW ANYTHING ABOUT THE BOARD BUT BECAUSE OF MY FRIEND HE SHOWED ME THIS SITE SO I HAVE MY ANSWER. THANKYOU VERY MUCH FOR YOUR TIME.
    DAN FROM
    CALIFORNIA
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What is the model of the ASUS motherboard you have?
    President:
  • 2,692 Answers
If that is all it was designed for , you can do nothing to change it,unless the BIOS upgrade allows more.
Posted on Mar 02, 2009
Not installed win7 on 512RAM
As per minimum requirements of the Windows 7 Operating system, it needs minimum 1GB amount of RAM Memory... Thanks
Mar 04, 2016 | Computers & Internet
Graphics are slow and choppy on a powercolor 1650pro 512 megs of video ram.Starts out fine,graphics are beautiful but af ter a minute of gameplay bogs down and becomes hesitant and choppy.
512 mb of video RAM may not be adequate for some games. There could also be an issue with how much general RAM you've got on the board.
Hope that's helpful.
Jan 13, 2011 | ASUS A7V600-X Motherboard
My laptop is running slow? when im in the internet my computer runs slow
Available RAM is very important for speeding up your laptop while surfing. Check your available RAM by:
  1. Starting the Task Manager (Right click on taskbar and select it)
  2. Select the Performance Tab
  3. Compare the Physical Memory vs Commit Charge numbers.
For example, my fast computer has 3600 megs of total physical memory compared to a commit charge of 1200 megs. Meanwhile, my older, slow computer has only 650 megs of total physical memory with a commit charge of 1400 megs. This means the slow computer is always making 'pretend' memory from hard drive space, and that is why it is so slow. This is most likely the case with your computer as well.
I hope that helps.
Jul 14, 2010 | Toshiba Satellite A135-S2276 Notebook
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
I Have a MAC OSX 101.5 can I install leopard
Here are the minimum specs your Mac will need to run Leopard, from Apple:
  • Intel, G5, or 867MHz+ G4 processor
  • 512 megs of RAM (though if you only have 512 megs of RAM you should get some more. Trust me, I'm a pundit)
  • DVD drive (Leopard is shipping on a DVD, and your Mac needs to read it to be able to install it)
  • 9GB of free disk space (though I bet if you customize the install and leave out all those printer drivers and extra languages you can save lots of space)
Go to your apple menu, and look on the "about this mac" If your machine doesn't have the mhz's you are out of luck. If you don't have a DVD drive, you are not going to be able to install either...
K
Sep 14, 2009 | Apple iMac G4 Desktop
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Memory upgrade for Compaq Presario 2195 us
This is helpful for process on changin ram.CLICK HERE
As far as i can tell your computer will hold up to 1024 megs of ram that is 2 512 sticks. Just pic up the other 512 and call it a day that way you know your maxxed out on ram anyway. Not sure if it will take the different size sticks as I haven't found anything on their site. TRY HERE
Jan 15, 2009 | Compaq Presario Notebook
FITTING EXTRA RAM INTO MOTHERBOARD
What you can physically fit and the space available is not the same thing, Crucial is an excellent site but it might say that you have the capacity to fit x megs but whether you have the empty slots is different (see the last paragraph), and you will not really know untill you open the case and look.
The actual fitting is simple enough if you can reach the slots without dismantling the whole machine!
Supposing you can clearly see and reach the slots, with the machine off, and the power cord removed - yes removed! Gently press on the white clips at either end of the fitted memory it will pop up, lift it out without touching the gold terminals, notice the slot in the bottom edge.
Now, and without altering the orientation, place it back in the slot lining up the slot to the peg in the receiver. Now with a little pressure you can clip the memory module back in the slot and the tags will pop back into the locked position.
Okay you have done it, its as easy as that. So when the new stuff arrives you will know how to fit the new modules.
Your new modules could have twice the value of the old ones, so if your board can handle say 1 GIG of memory in two slots, thats a max of 512 megs in each, you might have 2 x 256 megs fitted and there are no empty slots, so pop out the 2 x 256 and drop in the 2 x 512 making an upgrade of ½ a Gig (in each slot) giving a total of 1 Gig.
The probability is that there are four slots, two of which might be empty, its the combination making up the total that determines how much extra you can fit....
I hope thats clear??
BluRay
Nov 22, 2008 | Asrock K7VT4A+ Motherboard
Computers & Internet Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
