Question about E-Machines eMachines Desktop PC
When i turn on my computer nothing pops on the screen
My computer turnes on the power supply fan turnes on everything the hard drive fan turns on all lights turn on just nothing on the screen every thing is plugged in i tripple checked everything
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    unseat and reseat the memory inside of the computer. If you have more then one stick of memory do one at a time in each slot at a time to see if you get video.
  • Thomas F. Schneider May 11, 2010
    Download harddriver test software for Seagate or WD and run it to see if your hard drove is ok?
    Problem Solver:
  • 14 Answers
If you have another monitor, I would try that first.
After that, it could be the video card, so you could swap with a good one to be sure if you know how.
Last thing and probably the cause, is either a bad motherboard (most likely) or perhaps a bad cpu (less likely)
Some IT shops will let you bring it in and run some quick tests for the exact cause but my bet is the motherboard....
Hope this helps and hope I am wrong!
Posted on Mar 02, 2009
I change the power supply cause its not work and now its ok but there nothing display on the screen only the word say power seving
Assuming that you have correctly hooked up the power supply and that when you turn on the computer the power supply powers up as well as the CPU fan and the hard drive spins up, you have a video problem. While this COULD be because of a bad power supply, I think there is another hardware issue here.
You say you changed the power supply because it didn't work. I'd ask why didn't it work--did it suddenly make a popping sound or did you smell burning electronics? If so, when it failed, it may have taken part of the motherboard with it.
If you have an integrated motherboard (the video is actually part of the motherboard), then that is probably the issue here.
Just to be sure, disconnect everything BUT the CPU and memory and video. Then try to start it. If you see something on the screen (like a message telling you there is no boot device) then you can assume the hard drive or CD has gone bad. Reconnect the hard drive to see if it starts. Then the CD.
If you fail to get any image on the screen, assume that your motherboard is shot.
Mar 21, 2012 | Gigabyte GA-G41M-ES2L Motherboard
Dell loud fan noise
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
Jan 26, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
Voltage not going to cpu
Not sure just what you mean. If your computer is plugged into the wall and the power is turned on, the power supply should be on and the cooling fan turning. Also, the CPU fan should be turning and the hard drive should spin up.
Note that the power supply is the main component that must be supplying the power. If you don't hear or see the fan turning in the power supply and the little power light on the front of the computer does not light, replace the power supply.
If your power supply is running and nothing else is running, I would unhook all devices and leave just the CPU and video and memory in. If you get nothing, then the motherboard is probably bad.
Sep 22, 2011 | Computers & Internet
Computer will not turn on ? checked outlets,cleaned out computer , unplugged everything nothing connected to computer
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error
hope this will help
don
Feb 17, 2011 | Dell Dimension 8400 power supply ** FREE...
I have a computer that would do nothing when turned on, including giving no beep codes. Everything seems to be getting power - the CD drive, CPU fan, and hard drive all start spinning. I disconnected...
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 05, 2010 | Acer Computers & Internet
Start wont load window, just flahing light on screen. may have got virus
Remove hard drive, find out make and model of hard drive. Go to hard drive manufacturer's website and download testing software (if you have another computer with internet access). Should be a bootable ISO file. Burn the boot cd and run it on the host computer after reinstalling the hard drive. Sounds like a bad hard drive in my opinion.
Feb 20, 2010 | E-Machines eMachines W2686 PC Desktop
Computer turns on but does not boot windows, no bios screen
As you seem to not be a total novice with electronics, I would suggest you try unplugging everything with in the computer apart from the big plastic (Molex) connector from the power supply.
So unplug hard drive, cd/dvd drive, all pci cards, monitor and any memory.
PLEASE MAKE SURE THE PC IS OFF WHEN DOING THIS AND TURN OFF AT THE MAINS>
Turn your pc back on, you will hear a beep, nothing to worry about, its because you have nothing connected yet.
One by one start to connect the components back in the unit.
All this is doing is fault finding to see if its hardware related.
might be worth connecting your hard drive 1 at a time if you have more than 1 but the one with your operating system needs to go in first.
Add the ram 1 stick at a time aswell incase it the memory thats gone faulty.
Just remember to be careful with static if you can..
Check your graphics card aswell if you have added one:
Everything that I have read so far points to a graphics card failure..
http://en.wikipedia.org/wiki/Power-on_self-test
Jan 20, 2009 | Dell Dimension 2400 PC Desktop
Hard drive shuts off?? I think.
replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Dec 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
E-Machines eMachines Desktop PC Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
