Question about Sony PlayStation Portable (PSP) Console
Xbox 360 error E74
Its just a screen with wrighting and says error E74 and i need help to fix it, it has one red light on it
    Problem Solver:
  • 16 Answers
There is a high chance that its a scaler chip problem, or the av cables, try new cables, if that doesn't work, send it back to microsoft. the x-clamp fix might also work.
Posted on Mar 03, 2009
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Switchs on comes up with e74.has 1 red light flashing on front f unit
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance
click here to download.....................
Oct 14, 2010 | Microsoft Xbox 360 Console
One red light flashing on xbox360,code e74 showing on screen
If you have 1 red light flashing it is normally E74 or some other E error you need to stop the heat.
You can send it in and Microsoft will do it for you or you can repair it yourself using a good guide
Dec 23, 2009 | Microsoft Xbox 360 Console
Screen reads,system error and has a trouble code of E 74 What could be the problem?
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 28, 2009 | Microsoft Xbox 360 Console
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
1 red light
hope it helps...
Jan 04, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 1 red light
If everytime you turn on your XBOX 360 and it displays this message it could mean a hardware failure :
E74 Means : There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement
I would advise you call customer support
They are very helpfull and if your XBOX 360 is under warranty they will offer a pre-paid postal service to pick your XBOX 360 up , and will diagnose the problem .
If your based in the uk , the number is : 0800 587 1102
I hope this helps everyone
X
Jul 31, 2008 | Microsoft Xbox 360 Console
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red light Error) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Dec 17, 2007 | Microsoft Xbox 360 Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
