Question about Etymotic Research Isolator ER-6i Consumer Headphones
Sound in left earbud shorts in and out
Does anyone know how I can stop my left earbud from shorting in and out? It seem like it I jiggle the wires, the sound sometimes plays and sometimes cuts completely out.
  • Anonymous Mar 12, 2009
    Same problem.
  • 43 Answers
If its not hard to open the case, just solder the connection again (only if you found out that the problem is inside).
Also check the wire if it have 100% connection. You may also check skin of the wire. If found out no good, so possibly this could fix the problem.
Posted on Mar 12, 2009
1994 3500hd front left turn signal won't work
The wire feeding the front left turn signal is likely crimped or stretched and touching the body somewhere. Do you best to trace the left front turnsignal wire back as far as you can - even just jiggling it might give you short term solution (although it will probably come back).
The fast flash of the rear light is because the short up front is letting too much electricity run through the flasher module. This makes it run too fast. Find the short up front, and both problems will be solved.
Apr 22, 2014 | 1994 Chevrolet C/K 3500
I have an intermittent electrical fault on my 94 dyna wide glide. every so often it just cuts out as if the ignition has been turned off or the kill switch has been pushed. once it stops all the lights,...
"sometimes it starts after jiggleing the wiring loom"
That right there says you have a shorted/broken wire somewhere in the area that you "jiggle", so get an Ohmmeter and start testing in that area.
Mar 30, 2013 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
I found some pretty cool earphones... they are puregears purebeats headphones set. When I found them, the right earbud wouldn't make a sound unless I jiggled the wire by the speaker. And the left one...
The thin wire used in the leads breaks internally and there is no easy way to fix them, you could try to fit another cable to them but it is usually not very successful. Replacement is about the only option.
Mar 02, 2012 | Audio Players & Recorders
I think i have a "short" in wiring on my earbuds
Yes they can.
I have done a guide for headphone replacement plugs etc on my Blog Site.
If you can use a soldering iron or someone you know does, then you should have no problems.
Real Life And Real Charts
Feb 09, 2018 | Brookstone Black Buds Sound-Isolating...
Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
May 27, 2009 | Sony MDR-NC11 Consumer Headphones
Sweat got into earbud- sound very faint
That happens because the water and saline solution in the sweat are causing the wires inside the earbud shorting to each other, or shorting to the earbud casing that is grounded.
Let the earbud dry out in few hours or more, if the problem does not go away, then get replacement heaphones, it means that oxide formation on the contacts is causing a short.
Do not use shorted hearphones they can cause damage to the connected device.
Regards.
May 04, 2009 | Shure SE530PTH Professional Headphones
Head phone jack
Flip the Sansa face down with the headphone jack to the left. Take the cover off the battery then remove the 2 screws by the sync port. This frees up the plastic that covers the last screw. But before you can remove this piece you need to lift the 2 black tabs in the middle and slide your nail between the seam between the black and silver areas near the hold button. The rest comes apart easy or the couple I have fixed the headphone jack have.
Jan 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Skullcandy earbuds one earbud not working
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Aug 13, 2008 | Skull Candy LINK Earbuds Consumer...
Etymotic Research Isolator  ER-6i Consumer Headphones Logo
579 people viewed this question
Top Etymotic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Etymotic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
