Question about Kenmore Dishwashers
Water remians in the dishwasher after cycle
We just bought a used Kenmore model 15721 dishwasher and installed it. After running it one cycle to make sure it worked - it did except the water is still in the bottom. It is full not just a little bit. We did buy a new drainage hose and installed it along with the dishwasher. Can this be fixed easily or inexpensively?
  • 641 Answers
SOURCE: Dishwasher not resetting before new cycle
It look like you have a cold water supply problem- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). Check that water entrance valve work (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Posted on Apr 12, 2006
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
SOURCE: Dishwasher won't drain all the way
I have a siemens Model SL34A and it will run the whole wash cycle but at the end it is still full of water and will not drain . Tried drain declogger and checked all the hoses for clogges and dose not appear to be the probblem.
Posted on Feb 13, 2008
SOURCE: Dishwasher--water in bottom -end of cycle.
You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. once drained put it through another cycle. this should reset the drainage level. hope this works as it has for ours, bye
Posted on May 23, 2008
SOURCE: Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
Posted on Nov 28, 2008
Dishwasher keeps running to long
Most likely the hot water temperature is the problem. If you have a separate hot water inlet check that the water temperature is ok. But if you only have a single cold water inlet then the heater inside dishwasher may be faulty. Check if the dishwasher is still cold when you terminate the cycle.
Heater is part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66515752000/0582/0130000/P0101063/00003?blt=06&prst=&shdMod=
Apr 04, 2014 | Kenmore 665
.After running my dishwasher on eco/fast cycle,
If the dishwasher is completing the wash cycle without any problem then the suds can occur either because you not using correct detergent. This model does not tolerate the tablets. You have to use the powder.
Water remaining in the bottom of drawer is linked to drain hose either blocked or not looped high enough under the kitchen sink.
I would suggest check this document for correct installation.
Nov 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
665.15824000 dishwasher
What is your water temp. This model has 4 automatic water heat cycles built in to it and it heats the water to 145 degrees and won't let advance till that temp. If the water coming in is lower than 120 degrees it will add about 2 hours to your normal wash cycle.
Feb 12, 2010 | Dishwashers
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
Trouble shooting kenmore dishwasher
I have a kenmore ultra wash II Model #1675590 Serial # FC1024731
Will not run and water is standing in the bottom. I have checked the electrical breaker and tried different cycles. Can you help.
Oct 03, 2008 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Nov 18, 2007 | Kenmore 16253 Stainless Steel Dishwasher
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
