Question about Nostalgia Electrics CCP-509 Popcorn Maker
Popcorn kettle not heating up
Popcorn kettle not heating u. How to fix? plshelp
  • Anonymous Mar 31, 2009
    plug into the kettle needs to be replaced
  • Anonymous May 19, 2009
    Kettle won't heat, the heating element needs replacing, but I can't find where to get one.
  • 30 Answers
You can call Nostalgia Products at 920-347-9122. They are open Monday thru Friday 8-5 CST.
Posted on Oct 30, 2009
Can I replace the heating element on the popping kettle?
Refer this issue directly to the manufacturer/distributor for repair/replace advice.
Jan 23, 2015 | Kitchen Appliances - Others
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Jul 20, 2014 | Gold Medal 2003 Whiz Bang Popcorn Maker
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
I cant find my instuction manual
Pre heat kettle 5 mins. Put in oil, popcorn, and popcorn salt. Dump kettle when done popping.
Use 3 parts popcorn to 1 part oil. Measurements are different for each model popper.
Dec 25, 2013 | Kitchen Appliances - Others
My BELLA Theatre Popcorn Maker is not heating up. The popcorn kernels dont pop and the kettle is not heating up This is just the second time I used it. What is the problem???! Thanks
double check the kettle is firmly plugged in. If it is and not heating return to store. there are no repairs for that model machine.
Nov 26, 2013 | Kitchen Appliances - Others
I DO NOT HAVE COOKING INSTRUCTIONS FOR MY KPM-508 POPCORN POPPER
The instructions say make sure kettle motor is plugged in. Turn unit ON with switch on crown of machine. Allow unit to run for 3-5 minutes to heat up kettle. Turn unit off. Add 2 teaspoons of your favorite popcorn cooking oil to the kettle. Then add 1/4 cup of popcorn kernels to the kettle. Turn the unit on and close the door. When popping sound slows down turn the unit OFF. Flip the kettle over with the crank handle to empty the kettle. Repeat process until desired amount of popcorn has been popped.
Jun 09, 2011 | Nostalgia Electrics Helman Group KPM-508...
Our popcorn machine is blowing the circuit when the kettle heat is turned on. Is there any way to fix it or any way to just buy a new kettle?
Mine is doing the same thing. Did you get yours fixed yet? If so, what was the problem? Its got to be the wiring. If you take off the bottom square wiring cover access, you will see the two main wires and a grounder all connected. Sometimes the connectors melt with the heat. Maybe that is what is causing the short.
Oct 15, 2010 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Kettle does not heat up
Check the wires to the heating element inthe kettle.
Jul 05, 2010 | Waring WPM25 Popcorn Maker
Kitchen Appliances - Others Logo
712 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Shehu Pro
Shehu Pro
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
