Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
How do you restring the B&D 12" 18 volt cordless timmer? Thanks.
How too restring a kobart 40 volt cordless trimmer
Hi Bill,here's a owner's manual for your Kobalt 40 volt trimmer.It's on page 12.
Jun 24, 2017 | Garden
How do I restring Ryobi 40-Volt X Lithium-ion Attachment Capable Cordless String Trimmer
all the manuals are available here. If you reply with the model, I will find it for you and tell you how to do it.
Jul 29, 2014 | Garden
How to restring cordless weed trimmer
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Have a maytag dryer that is 9 years old. The timmer is clicking, the light inside is OFF when the door is open and when I close the door it wont run. I have taken out the thermal fuse (the big one) and...
if the light is out check the door switch as this is a s.p.d.t. switch used to operate the light with door open and the dryer circuit when door is closed,otherwise if its electrically heated with an element,make sure the units getting 240volts,if you are only getting 120 volts it will let the timer or motor run,but only the component thats on the leg/phase that is still hot,tandem pole breakers need to be re-set as they can show good but one leg can be out then only 120 volts instead of the needed 240 volts to heat the unit,a gas fired dryer only needs 120 volts to operate, otherwise then it can be the hi limit thermostat on the element housing or the cycling switch,all need to be good,because its a series circuit,and any one will kill one leg of power if its open/bad
Jun 11, 2011 | Dryers
How do I restring my strimmer? Model no.GL575C
turn trimmer upside down and pull spoolhead off wind new string clockwise
Aug 03, 2009 | Black & Decker String Trimmer Cordless 12"...
Timmer assembly
this a 115 volt single phase timer you can buy the timer at or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Oct 30, 2008 | Hobart D300-6036 Mixer
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
288 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
