Question about ASK Proxima C170 Multimedia Projector
ASK Proxima c170 Power Supply Failure
The power supply on my ASK Proxima c170 has failed. I would like to replace it with a generic power supply so that I may cheaply repair my projector. How do I find the specific specs on this power supply, or can you point me towards a power supply that I could use to replace it, ie something from www.jameco.com
  • Anonymous Mar 25, 2009
    My projector refuses to come on no matter what I try. No LED activity so I assume that my projector's power board is on the fritz.
  • 74 Answers
I really doubt you'll find a generic power supply for this unit. I can repair this power supply for you at a low cost. I repair power supplies. My ebay ID is Gtitubro
Posted on Aug 21, 2009
My Proxima c170 projector will turn on and run for about 10 minutes, then the entire unit shuts down. It's as if the power was turned off.
Probably is a failed capacitor in the power board. Open the case and look for the can type capacitors with bulged tops and replace them if you can.
Feb 26, 2015 | Televison & Video
C170 Multimedia Projector: Won't turn on...
if it has no signs of life at all it is the power supply, another tell tell sign is if you look at the lamp and see bubbles in the mirrored part of the lamp.
May 17, 2010 | ASK Proxima C170 Multimedia Projector
Replaced bulb for a proxima c160 bulb won't strike led power button flashes red what can I do
You may have purchased an aftermarket generic lamp. The chances that the lamp is defect is about 20% with the counterfeit products....Read here for a better explanation:
http://www.fixyourdlp.com/guides/ask-proxima/sp-lamp-017/ask-proxima-sp-lamp-017-lamp-replacement-guide.php
I also suggest buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Apr 26, 2010 | ASK Proxima C160 Multimedia Projector
Elevator leg stuck
push the button like you are trying to put your finger thru the top. if that fails you can push the button and try to pry it loose with a flathead but you run the risk of stripping the teeth on the leg. those are your only options unless you want to take it apart so you can see the mechanism and try and figure out the problem that way.
Mar 19, 2010 | ASK Proxima C170 Multimedia Projector
No power
if there anre no leds lit on the top, the power supply needs to be replaced.
Jan 19, 2010 | ASK Proxima C160 Multimedia Projector
Proxima LP240/250 power supply failure bypass
It's easier to repair the power supply if you're going to that length. If you have a power supply failure, and you already know the voltages, you should be able to trace the failed components. If not, let me know and I'll get you up and running again.
B
Dec 30, 2009 | ASK Proxima Proxima DP2000X Multimedia...
My Ask Proxima won't turn on
if there is no amber led, the power supply is bad. if you have an amber led and the button won't work, there is an obstruction under the button panel. if the led is red and no fans come on, the fans or the power supply is bad. if the fans come on but no light, the colorwheel is bad.
Nov 03, 2009 | ASK Proxima M2+ Multimedia Projector
Ask Proxima will not start up
If it has no power at all or has power but fails to start, it is most likely the power supply needing to be upgraded or replaced. If you look at the projector with the top off, there should be a green wire going from the top of the main board (it is soldered to a orange cap in a group of 4) leading to the underside of the power supply. If you don't see this then your power supply is probably one that was never upgraded.
Oct 25, 2009 | ASK Proxima M2+ Multimedia Projector
Image points at ceiling
This is a problem with the feflector, and is quite common. It was probably moved or bashed whilst in transit, and can only be repaired by a professional.
Oct 25, 2009 | ASK Proxima C170 Multimedia Projector
ASK Proxima C170 Multimedia Projector Logo
821 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
