Question about Sony STR-DG510 Receiver
My receiver is protected
How do I get it out of protected
    Sergeant:
  • 319 Answers
Usually its a fuse, or a diode on the board, specifically designed to blow to save the components.
Try taking the cover off, and inspecting the circuitry for broken diodes and resistors. also note if the fuse is popped or not.
Hope this helps! pls rate well!
Posted on Mar 02, 2009
Sony receiver stR se-501 found fuse burned after replaced turned on the flashing massage PROTECT come on . Did I miss anything?
Protect typically means that the fuse blew because something in your receiver went bad. It's now protecting your speakers from that badness. You need to get the receiver fixed or replaced.
Jun 16, 2015 | Sony Str-Se501 Stereo Receivers
Where is amp curcuit protection in onkyo sr
There are plenty of protect circuits in your receiver. Each chanel has one as well as dc protect and thermal protect etc etc. More than likely you have a blown channel that needs to be rebuilt.
May 17, 2012 | Onkyo TX-SR604 Receiver
How do you reset the protection mode
The protection function has been activated because it has sensed an output load problem, turn receiver off and remove the speaker wires, this will reset the protection circuit. Now! turn the device on and turn the volume right down, if the protection mode stays off it indicates a short in the speaker wire or one of the speakers, but! if the protection circuit comes on with "the speakers and wires dis-connected" it means there is a short in the audio outputs in the receiver itself, this can only be rectified by having the parts replaced.
Mar 02, 2011 | Sony STR-DE585 Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
How to bypass protection mode on my sony receiver
The protection mode is there for a reason...the main one being to protect your speakers in the event that there is an issue with the amplifier. Bypassing the protection can easily result in the destruction of your speakers and the unit itself. Your receiver needs to be examined by a real live technician.
Nov 27, 2009 | Sony STR-DE597 Receiver
My Sony receiver is flashing protect mode
Disconnect all speaker wires at the receiver. Then power the unit on, if it stays on, post a comment on this thread and I will help you troubleshoot further. If "Protect" remains on, you need to have your receiver serviced. Hope this helps.
Aug 23, 2009 | Audio Players & Recorders
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Receiver Blinks PROTECT
how many speakers have you got on to it
Dec 07, 2008 | Teac AG-V8060 Receiver
Denon AVR3300 - Resetting activated Protection Circuit
Hi
Remove all speakers cables or wires and check all from behind the Receiver. if there are any loose terminals or any metal object in between the terminals.
though it might be a coincidence that you have a problem in the Receiver.
unplug the power cable from the wall socket and remove all cables.
after you remove the cables plug the power cable in the wall socket and try if you see the protection displayed , the receiver needs service.
Good Luck
Regards
Nov 02, 2017 | Denon AVR-3300 Receiver
Sony STR-DG510 Receiver Logo
325 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
