Question about Philips GOGEAR SA6045 MP3 Player
I think i unplugged my mp3 player too soon and it is stuck showing the hookup of the computer to player icon on the screen. I cannot turn the player off and it is not recognized when connected to the computer any longer. any help?
    Sergeant:
  • 319 Answers
My suggestion: let the battery drain, and see if it reboots upon a chargeup afterwards
Posted on Mar 02, 2009
IPOD not restoring
Download the latest firmware from apple and update the firmware and it will be OK
Oct 23, 2009 | Apple iPod touch Second Gen (8 GB,...
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
Ipod wont show up on itunes
In order to get an Ipod to work on your computer never plug it into a USB hub. The hub does something to the power of the device that causes it to not perform, be recognized, or charge. Find a spare USB port to plug it in and see if it will find it.
USB hubs do not work on external hard drive devices. Jump drives will work on a hub
Jun 05, 2008 | Apple iPod MA446LL/A MP3 Player
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 17, 2008 | Apple iPod MA446LL/A MP3 Player
Icon doesn't show up in my computer
Do a firmware upgrade first. If not allowed, then download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
"Safely remove hardware" is a normal function of Windows - it allows you to disconnect your Mp3 player without messing it up (unplugging any mp3 player while it is still "thinking" is the number one reason for mp3 player failure - always be patient with mp3 players, and try to always use the Safely Remove Hardware feature of Windows).
-Tha Mp3 Doctor
Feb 03, 2008 | SanDisk Sansa Clip MP3 Player
The sansa player icon doesn't appear
I had the same problem and someone recommended downloading window media play version 11. Apparently the lower versions of media player do not have the correct driver. My sansa clip works on my Lenovo laptop and it has windows media play version 10. So I think vresion 10 or higher will work. Hope this helps.
Feb 02, 2008 | SanDisk Sansa Clip MP3 Player
Stuck in "sandisk initializing screen"
To those that are having problems with the MP3 player not being recognized. With Windows XP there is a little Icon on your Systems Tray that is called the "Safely Remove Harware Icon". Not using this Icon when unpluging MP3''s or zip drives can cause your PC to no longer recognize it. Toshiba Satellite laptops are known for this, others probably have the same problem. The solution here is to install the latest update of the ACPI Flash Bios for the Toshiba Satellite computer. Maybe this is also the problem with other PCs. To prevent these problems allways click on the Safely Remove Hardware icon before removing the MP3 player or any USB flash drive
1 With your m240 set to MSC and connected, go to "My Computer" and "right click" on the "Sansa m240" icon and select "Properties"
2 In that window, select the "Hardware" tab
4. In that "All Disk Drives" window, highlight the "Sansa m240" drive and select "Properties" (at the bottom)
5. In that window, select "Policies"
6. And there, set it to " Optimize for Quick Removal" and click OK and OK again
Dec 02, 2007 | SanDisk Sansa m240 MP3 Player
Hey
It is easier to reformat the mp3 player. When the mp3 is plugged in to the PC, go to my computer, the double click the mp3 player there. You will see internal storage, right click that and click format. You will lose all the stuff on the mp3 player.
Oct 26, 2007 | RCA Lyra RD2765 MP3 Player
Won't charge
i think battry must be replaced from mother company or be checked
Jun 04, 2007 | Acer MF35 MP3 Player
Won't let me delete!!
You must 'release' the M200 from your computer before unplugging. With Windows, find the little icon on the bottom right of the screen...it looks like a card with an arrow over it...put mouse arrow over it and click with left mouse button...then select the drive the M200 is connected to...then viola...after dialog box pops up, unplug. Steve
Dec 27, 2006 | SanDisk Sansa m200 (2 GB) MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
65 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
