Question about Norcent Technologies LT-3222 32 in. LCD Television
Norcent 32 Nprcent 32" tv, I have a picture but sound goes on and off
  • lhappel Mar 02, 2009
    So what do I about it? It is only on some stations and seems to happen during commercials.
    Novelist:
    Scholar:
  • 95 Answers
Is the sound coming from the TV speakers or from an attached component?
If from the Component, use the TV speakers if it has one. If the TV speakers stay on then you have an audio component issue.
E
Posted on Mar 02, 2009
Norcent dvd home theater plays good sound, but no picture
check that ur video input on the tv is set correctly. you can do this by turning on ur theater system first , when u get ur sound grab the tv remote and select the tv input button or if u don't have said button try thr tv/video button untill u get a picture. ( this of course a suring that ur video cable is connected ) hope that helps
Jun 03, 2012 | Norcent Technologies DP-2700 System
Sound no pic. after on for 20min then turned off back on and pic. now it will not get pic just sound
Your TVs CRT socket is faulty. CRT socket is one that connect the base of the picture tube, and can be located on the base card of the tv. It is soldered directly to base card and can be replaced. Unplug the base card from the picture tube neck [Caution: never damage the neck of the picture tube. Only slight pressure should be applied], desolder it out and replace it with a similar type.
Oct 16, 2010 | Norcent Technologies2703 27" TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a norcent 32'' tv and later when i turn it on there is no picture but i hear sound, the control dont work either. I have to unplug the tv and wait a little and then plug it back in and it will work...
The LCD inverter backlight board is dying.Replaced this board to solved picture problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is a long board in shape.
Mar 03, 2010 | Televison & Video
My tl3222 norcent whent black.Good sound.any ideas? Tv will display channel number and shows audio type (mano) when channel is tunned.It takes a while for the standby light to go green.you have to turn the...
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees. But you could also have a bad main/control board which is where all the input jacks and tuner are mounted. These boards are more expensive, but not sure of the actual cost.
Sep 07, 2009 | Norcent Technologies LT-3222 32 in. LCD...
No picture no sound
may you do have a defective jungle ic or eeprom
Jul 26, 2009 | Norcent Technologies2703 27" TV
Went out no picture sound nothing
no picture no sound nothing but when connect conputer have picture and sound plese help thank
Apr 28, 2009 | Norcent Technologies LT-2722 27 in. LCD...
Norcent PT4291HD Plasma TV, no picture
The power will not stays on, it keeps turning off by itself
Dec 01, 2008 | Norcent Technologies PT-4291HD 42 in....
Norcent LT-3222 32" LCD HDTV SCREEN TURNS GREEN
I have the same problem and need help. Have this TV over 5 years and don't know what to do this it
Aug 29, 2008 | Norcent Technologies LT-3222 32 in. LCD...
Norcent Technologies LT-3222 32 in. LCD Television Logo
135 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
