Question about Dremel & Stylus Lithium Ion Cordless Rotary Tool
Dremel Stylus 1130-01 will not charge.
This is part of a Dremel Duo set. The Screwdriver charges, so I don't think it's the battery pack. Is it possible to change out the lithium ion battery in the stylus or must I buy a new one?
  • Anonymous Apr 15, 2009
    ONE OR MORE OF THE CELLS HAS FAILED AS HAS MINE,NOT HAD A GREAT DEAL OF USE SO VERY DISAPPOINTED WITH DREMEL,ALSO HAVING PROBLEMS LOCATING A DEALER LISTING THE BATTERY AS A STOCK ITEM.ALL OF MY CHEAPER MINI DRILLS LASTED FAR LONGER
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: useing a dremel stylus
I would call Dremel tech service at 1-800-437-3635 and ask them and also get a copy of an instruction manual for future use.
Posted on Jan 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dremel Stylus model 1100
I would contact Dremel.com and talk to their tech department about a warranty repair for this tool.
Posted on May 08, 2010
  • 28 Answers
SOURCE: Replace the docking station-charger of dremel stylus
ebay.com or www.craigslist.com
Try to find a used one maybe?
Posted on Sep 01, 2010
Zim1308
  • 543 Answers
SOURCE: Dremel Stylus only charges for 2-3 minutes then
This is the charger, its getting a reading from the battery that its charged when it isn't. I don't know exactly how that charger is wired but, to be suroe it is the charger, as I have had similar problems beforehand.
Posted on Jun 17, 2011
Testimonial: "Brilliant! thanks very much for the very prompt reply - well impressed!"
How can I locate capcisator for Dremel Stylus Lithium-ion model 1100 ? It has got charging problem.The Stylus is a cordless tool.
Do you mean a capacitor? Is it the charger or is it the battery? The capacitor are plain types can be found at any electronic parts store. I think the main one is 220uf. Be sure an check each for problems.
Jan 18, 2015 | Dremel Tools & Hardware - Others
Red light flashing very fast and not charging fully
How long is it charging until the light goes from flashing red (no charge) to yellow to finally green (full charge) ? If it's not at least 2 hours, sorry I don't have my Roomba papers available, so I'm guesstimating here, it's not getting a full charge. If you can put a voltmeter on the " fully charged" battery pack, that might tell you if the charger is the problem. Clean off the metal contacts where Roomba meets the two metal contacts on the charger. Also just because a battery pack or set is new doesn't mean it's functional. I had a new Apple battery for my laptop that didn't work when I replaced an older one.
Sep 26, 2014 | iRobot Roomba 530 Robotic Vacuum
Dremel Stylus only charges for 2-3 minutes then stops
Jun 17, 2011 | Dremel & Stylus Lithium Ion Cordless...
My relatively new stylus runs for a short while and then turns itself off! Any small restence on the tip while in use also seems to turn it off. Please tell me what the possible cause is.
Battery is flat or has a problem, the dremel does monitor voltage/current and shutdown to prevent battery damage, failure or fire. First step is to ensure the charge is working properly.
Dec 11, 2010 | Dremel Stylus Rotary Tool
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
Porter Cable PCL180DK-2 combo is useless right out of box
This should help address your question...http://blogs.popularwoodworking.com/editorsblog/PorterCable+Faces+Issue+Headon.aspx
May 09, 2009 | Porter Cable-Cable PCL180DK-2 18-Volt...
Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel & Stylus Lithium Ion Cordless Rotary Tool  Logo
1,128 people viewed this question
Top Dremel Tools & Hardware - Others Experts
xboa721
Level 1 Expert
Mike
Kirk Augustin
Kirk Augustin
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
