Question about Microwave Ovens
Display shows nothing
The display shows nothing. I accidentally put an object with a metal wire and it caused a lot of sparks. I cannot get any settings to work. I can't get the microwave to turn on.
  • 3 more comments
  • Dieter Schmied Mar 02, 2009
    I have left it set. Now there is not even the clock and I was getting a beep on the cancel button after I pushed a lot of buttons. I think it has taken its last breath. I also found the fuse and it is okay.
  • russellaha Mar 07, 2009
    my mother in law says she was using the timer to cook something else when everything clock, lights. fan, she was here alone so i don't know for sure if she was was using the kithen timer or the cook timer.
  • Anonymous Mar 08, 2009
    This is a Maytag model mmv5000adw serial # 10000219um.
    question Where is the fuse?
  • russellaha May 11, 2010
    this is a maytag model mmv5000adw serial # 10000219um
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for about 5 minutes. Then let us know if the hard
    reset does not fix it.
  • Microwave Ovens Master
  • 9,042 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
Also, Please reply back with your brand and model number so we can help you.
Posted on Mar 06, 2009
  • William Miller
    William Miller Mar 06, 2009
    (Sorry, I mean my post
    above to be a Clarification Request instead of a Solution - please don't rate that solution until we're sure what will help you)
  • William Miller
    William Miller Mar 07, 2009
My microwave model mv1526w when I press start it start to spark...What makes it spark and can I fix it?
It might be the appliance isn't properly grounded or it might be it is faulty or it might be there is something inside that is unsuitable.
Microwave ovens should not be operated with nothing inside and only suitable containers should be used to hold food for heating. Cups or plates with gold painted rims and metal containers and those containing metal are likely to cause a veritable electrical storm inside.
Mar 06, 2017 | Microwave Ovens
I have a 2 month old whirlpool built in microwave, model no amw 498 ix. An alarm has just started sounding about every 10 minutes and the display shows code 'ERR2'. There is nothing about this in the
try to disconnect the electricity and remove any metal objects colse to it or mobile phones and reconnect it back again and see what happens.
Dec 03, 2012 | Microwave Ovens
Microwave was run empty and now it won't run. Display works but no fan or microwave. What to do?
The magnetron does not fair well when running empty, the thermal fuse usually kicks in if a metal object was put in by mistake, but should be checked along with the door switches.
May 31, 2012 | Panasonic Microwave Ovens
Smells like its burning
check to be sure there is no metal objects bc this causes microwaves to reflect back to the magnetron causes sparks and burning smells in the microwave nd check that all food that may have spilled is cleaned up
Feb 05, 2011 | Emerson Microwave Ovens
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
there is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Can you run a microwave with nothing in it? Someone told me that just putting a sponge in it will ruin the microwave.
hi, running it with nothing in it will cause it no harm, the only object that will cause it any harm is if you place anything metalic inside it whilst it is switched on.
to clean a microwave most people place a bowl of clean water inside and put the microwave on high for 5 to 10 min doing this breaks up any grime stuck inside the microwave making it easier to wipe off, you can also put a wet cloth in a bowl and switch it on doing this does the same as a bowl of water.
so the only thing that can cause damage is anything with metal in it this will cause it to short out.
hope that has been some help to you
Aug 18, 2010 | Sharp R-1480 Microwave Oven
There is sparking from a small metallic plate mounted on the right side of our sharp R-508HS microwave, along with an ugly humming noise. this plate is adjacent to the magnetron grille. i had heated a...
Sparking in a M/wave is a problem as it can damage the works. Not sure what the plate is you speak of, Generally all metal objects are painted with enamel to prevent sparks. The humming is a worry though as it indicates something not functioning correctly in the Magnatron which is a large transformer like object. M/waves are not as expensive as they once were and can be picked up second hand under warranty from cash exchange places for about $30 onwards. I recognise that even that is an expense you dont want, but to continue to try and use a sparking MW is dangerous and is often not worth the money you spend on repair, against a used or refurbished one with a warranty.
Sorry I cant come and take a look for you ( I am in Australia) and help you out any further. But my advice is if you cant fix it yourself easily, Ditch it and replace it with a used one.
Sep 24, 2009 | Sharp R-508HS Microwave Oven
Microwave wont work on generator power!
PLEASE CHECK THE POWER CONSUMPTION ON THE APPLIANCE i think it might be a lot more than ur gen set can supply
Jul 08, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Microwave Ovens Logo
53 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
