Hello install this program from here:
http://www.malwarebytes.org/products/malwarebytes_free/
And run a full scan when the program is installed.
Please do not activate the trial period.
Install a better antivirus program, like microsoft security essential.
And delete the others you might have.
Good luck
SOURCE: remove write protect on my usb flash drive
you can try to remove the viru with malwarebytes and unlocker
http://www.malwarebytes.org/mbam.php and http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
Thanks
SOURCE: Trojans wont go away. Hijackthis SCAN help
I've had VERY good luck by using this Kapersky Antivirus rescue. Here is a link to that, courtesy Brothersoft: http://www.brothersoft.com/kaspersky-rescue-disk-197959.html
Scroll down, it is a 102MB download.
Download this to a known clean machine and burn a CD. Once burned, put it in the infected machine and boot. It is a linux based OS Live CD, so it won't be infecting this disc. Live CD's are great, they take a little while to boot though.
Make sure you have an active internet connection as the program will update itself before scanning. If if says it won't mount the internal drive, choose Force Mount. In Settings, choose scan all files, set level to highest threat level.
This CD saved my **** and is now a permanent part of my CD collection!!!!!!!
After this finds the problems, download and install and run both Malwarebytes (full scan) and also Superantispyware (full scan). After those, download Avira-Free AV software.
By this time, you should have killed the beasties dead in their tracks!
Best Regards,
Tom
SOURCE: Cannot find shooter.exe
Sounds like a Malware message. Boot your computer to the desktop, or if you are unable, boot to Safe Mode (F8). Download, install and run MalwareBytes (MalwareBytes.com). Hope that helps.
SOURCE: Unable to install Mcafee Security suite (confling software)
Check the following video for installing mcafee antivirus
http://videos.iyogi.net/antivirus/brands-we-support/mcafee/how-to-install-mcafee-antivirus-on-your-computer.html
The process "winlogon.exe" runs in the background. Winlogon
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager."
Microsoft designed Windows so many small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that runs on start-up, and its primary function is to monitor the use of other applications.
Winlogon.exe typically only runs for about a minute or two when Windows first boots up, so if for some reason it is still running five or 10 minutes later, it could be infected.
Spyware and other malware would infect this application because it can manipulate other programs in Windows, causing problems.
If this is the case, the file might need to be removed.
if you want to remove this from
Open "My Computer" and select the "C:" drive.
Double click the "Windows" folder, then select "System 32." Navigate through the System 32 folder until you find "Winlogon.exe."
Click the "Winlogon.exe" file and hit "Delete." Select "Yes" when asked if you're sure you want to remove the program.
hope this helps
