Question about Bionaire Humidifiers
Humidifier EMPTY/CLEAN light is on even though it is full~
The EMPTY/CLEAN light on our Bionaire Clear Mist Humidifier is on. I have cleaned it thoroughly, and it is still lit. The humidifier itself will not run now, what do I do? The model No. is CP 0305, and I cannot find anything online about it. There is another one that resmebles it, but there isn't even info/help for that one eiher.
Ours is white, and it has 2 tanks. It holds 3 gallons, and is warm mist.
SOURCE: honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Posted on Jan 18, 2008
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or may be able to clean around the shaft with w d 40
Posted on May 30, 2008
SOURCE: My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
Posted on Jul 09, 2008
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
Bionaire BT-200 ultrasonic humidifier have stopped misting, though I can hear a hum as though something is still working. I have two of these in the same state.
I have the same model; it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up. The scale keeps the disk from vibrating.
Jan 24, 2017 | Bionaire Humidifiers
Empty light keeps coming on even though it is filled.
Probably needs a good cleaning. The float switch might be sticking.
Oct 02, 2013 | Bionaire W6s Humidifier Filter Wick
HOw do I clean the cool mist humidifier?
If there is a lot of scale and mineral deposits , you can run a 50/50 solution of White Vinegar and water thru it, by half filling the tank with the solution. When it's almost empty, turn it off, empty the remainder of the solution and flush the system with clear water. In the future I recommend that your use bottled Distilled Water, instead of tap water.
Feb 17, 2011 | Walgreens Cool Mist Humidifier Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Looking for manual instructions to clean vaporizer with vinegar
all you need is a capful of vinegar mixed into the water and it will clean it like new again
Feb 21, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
soft brush.
May 19, 2008 | Humidifiers
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Humidifiers Logo
105 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
