Question about Philips 37MF231D 37 in. LCD Television
No video input
After switch on, approx 30 sec a message "Attention No video Input" on screen and switching off themself.
5 Suggested Answers
SOURCE: Video In or INPUT
It depends on your television set but there are two common ways to do it. One way is through the menu function on your television. The other is by pressing the Channel down button on your television or remote control and the option will appear.
Posted on Dec 27, 2007
  • 171 Answers
SOURCE: Strange message display when switched on.
The "TV ONP" message is happening because the DVD recorder is waiting for you to complete the "initial installation" on the TV (where you will select what language you want to use and a few other basic settings).
Provided that your DVD recorder is hooked up to your TV properly, you should turn on your TV and see the "initial setup" screen for the dvd recorder. Use your DVD recorder's remote control for this screen.
See page "30" in the manual that was posted for instructions on going through these screens. Note, though, that page "30" in the manual, is actually page 44 on the pdf file.
To summarize what the manual says, it basically says:
- Use the remote, pointed properly at the dvd recorder. Use the four-way pad and the "OK" button to navigate the menu.
- pick your menu language from the menu shown onscreen
- now pick your "audio language" from the menu
- now pick your "subtitle language"
- then pick your "tv shape" (e.g. widescreen or normal)
- connect your cable tv or satellite to the dvd recorder and press ok
- wait as the dvd recorder automatically programs in the available channels
- once done, "Auto ch. search complete" will appear on the screen.
- press the "SYSTEM-MENU" button on the remote to remove the menu and begin normal operation
You're done!
The recorder will loop through all the channels on your cable tv and "autoprogram" the working ones into it, so part of the instructions that you read on the manual will talk about setting that up. If you have a digital or proprietary cablebox that doesn't use the traditional TV channels (e.g. the tv is supposed to just be on channel 3 all the time), then the dvd recorder will only find that one channel, which is fine.
Posted on Jan 31, 2008
  • 52 Answers
SOURCE: Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Posted on Mar 09, 2008
SOURCE: 170c lcd screen saying no video input
hey i relise you had this problem a while back but i am having the same problem, may i ask how you resolved this problem?
regards
adam
Posted on May 21, 2009
tmatrix540
  • 69 Answers
SOURCE: Screen message reads
Try another monitor with your computer if this still doesenty work then your graphics card is at fault
Posted on Nov 26, 2009
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Have fujitsu esprimo mobile laptop screen keeps switching itself off intermitantly (approx every 30 secs) anyone know why????
system software is probably corrupted, have it fixed by a capable computer guy or if it is still under warranty have them fix it for you
Oct 25, 2012 | Fujitsu ESPRIMO MOBILE V5515 V5555 V5535...
On the screen is only /attention / entering sleeping mode/no video input what is a problem?
1.This means that your comp is supplying power to the comp...
2.check video cable...unplugg and replugg...
3.Still not resolved...unplugg all the devices from the back including the power cable...
4.then press and hold the power button for 20 sec...then connect the power cable keyboard mouse and the monitor cable...
5.then try to start the comp...
6.still not fixed...switch the voltage selector at the back...
7.still not fixed need to reset the ATX cable inside the comp...
8.Still not fixed can be a hardware problem...
Apr 06, 2011 | Computers & Internet
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
The HDMI doesn't work properly
HI
The resolution is only set by the sending unit, in your case the cable box. You need to change this to at least 720P something the your TV can handle.
Now once you have down this, to try and solve your HDMI problem I suggest you do the following.
Switch-off your cable box and the TV set, unhook the HDMI cable.
Now reinsert it carefully to make sure it connects properly on both sides.
Now first switch on your TV and set the input to Video 6 ( your HDMI channel )
Now wait for 30 secs. Switching on your cable box.
Do not press anything and check if your picture now stays on without shut-down.
if the menu and other startup screens on the cable box is not flickering, but the normal picture you might have a HDMI conflict with your TV set.
O, you cannot change the input types.
Hope this helps!
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
Can't open windows, computer screen has
bad onbord video need new video card ok if uuse atoi make sure pluged in u will have to go out buy new one that one toooka crap ok they do gota have cpu dusted out ever 2 3 mo gets to hot kills vvideos cards ect best to buy new one just video card
Jan 30, 2008 | Computers & Internet
Dec 20, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 37MF231D 37 in. LCD Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
