Question about Dryers
Cant find heating element/coil
Model # DDSR475ET5WW dryer --took it apart and the coil was busted where can I find a replacement . On the GE sites it cant find this model the closest is a model that ends in 4WW--is it the same?? are they interchangable???
    Guru:
  • 462 Answers
The last letters are for a color usually and the last number may be for a particular run or Family indicating it was the family in line before your was made. My guess is that if it gives you a voltage rating of what yours is and it looks the same - its most likely the same.
Posted on Mar 02, 2009
My dryer shuts off before its time and not heating
Model?
On a model I just repaired here's what I found:
Model: 110.69422801
Kenmore Electric
No heat. although sometimes it had heat for a short time. Suspected that the heating element was faulty (i.e. cracked heating coil). Nope. Checked hi and lower thermostats and both were good. Took apart timer controller. Found that the contacts inside were worn/burnt. Item is designed to fail. Slightly bent one of the contacts to make better contact and it is working. Ordered new timer/controller ($45 including shipping from "One Appliance" on line). Easy to replace. ALWAYS disconnect the power when servicing!!!
Mar 22, 2016 | Kenmore 800 6983 Electric Dryer
I just recently took apart my GE Dryer, model number DJSR473ET1WW to fix a loud noise. I put it back together and now I realize that the back of my dryer is extremely hot. Is there something I may have...
Sounds like you hava a venting problem. Disconnect the vent on the back and see if it still gets hot.
If it gets hot when the dryer is not on, then the heating element coil is shorting out on the element pan.
Hope that all helps.
Jan 15, 2010 | Washing Machines
HOW DO I REPLACE HWTING ELEMENT
depends on the model and type of dryer and if it's a "cake pan" re-string "or encased element there are too many variables w/o brand name and model numbers
Aug 04, 2009 | GE Dryers
My dryer takes long time to dry the clothes. It
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
Jul 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Replaced dryer belt dryer was heating now isn't
There could be 2 problems coming into play here.
1. Check to make sure there is no blockage in the vent piping. If the vent is blocked and the air cannot discharge from the dryer, the heating element will overheat and the overtemp thermostat will turn the heating element off.  (By the way, Blocked vent is usually the No. 1 Culprit in problems like this.)
2. Check the heating element and make sure that the heating coils are all intact. An open or shorted heating coil will cause the same symptom.
Dec 14, 2008 | Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Heating
The most common cause of heater failure is the thermal cutout/thermal fuse/temperature cutout(any of a dozen names for the same thing from different manufacturers) a device on the exhaust ducting near the fan housing. on over temperature, when the air temperature is hotter than the normal range set by the thermostats, these units melt out,
they are not resettable, they are replaced, ~$8 each, except where manufacturers are gouging
they look usually like this 2543d18.jpg or this d733938.jpg conduction good, open circuit fail
common to many dryer models the local parts guy will have them to suit, even if they are labelled with a different make or model
Oct 05, 2008 | GE DBSR453EBWW Electric Dryer
Heater coil
have to remove drum to acess hater coil ..all ge dryers are behind drum ck continuity first also ck for burnt wires
Sep 04, 2008 | GE Dryers
Dryers Logo
121 people viewed this question
Top Dryers Experts
