Question about Vtech 5.8GHz Analog Cordless Phone
Buzzing My phone's answering machine function buzzes and echoes as it is recording a voicemail and when playing it back. As it is recording it has a tremelo effect such as that used on guitars when playing with an echo effect
    Master:
  • 505 Answers
You need to ring up ur service prover you they can fix the line for you its not the phone
Posted on Mar 09, 2009
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2014 | Panasonic DECT 6.0 Expandable Cordless...
How do I record a voice clip to be played when I do not answer an incoming call ?
What you describe is a function of your telephone service provider, not your handset. Go to your voicemail and listen to all the options. One of them will let you manage your voicemail settings, such as setting a greeting.
Jul 26, 2011 | Samsung Rugby SGH-a837 Cell Phone
I am having problem with leaving messages. Everytime someone try to leave msg..voicemail say your memory is full, please hangup..but there were no messages in there..I also turned the machine off to see if...
Deleting messages (memory may be full).
Verify you do not have old messages on the the system. After the system plays all new messages, press Play/Stop again or from the handset Select 2:Play.If you find messages, delete them during or after they play.
After you listen to your messages, the voice message icon turns off. If it doesn't or if you can not receive messages, you should try to reset it: With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Make sure the Record Time is not set to Announce Only.
Jun 20, 2011 | Uniden DECT 6.0 Cordless Phone
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Voicemail messages recording and playing back
turn off turn back on keep trying if not turn off leave 1 day it should work
Jul 19, 2010 | RCA ViSYS 2-Line Speakerphone
Buzzing on DVD recorder when recording
The buzzing sound were feed back from power supply regulator if you can replace all of electrolytics capacitor in power supply block you will fix this problem or replace complet PCB
I need the correct model of your JVC DVD recorder
Dec 07, 2008 | Televison & Video
I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
Sep 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Setup answer machine
My phone echos when it plays the answering machine with my recording, how do I stop it from echoing?It is a vtech 5.8ghz phone.
Sep 06, 2008 | Vtech ia5845 Twin Cordless Phone
In play-back, buzzing/static after 10+ seconds of recorded message
unplug power adapter for about
30 minutes (this solved my problem of a buzz on the outgoing message)
Mar 09, 2008 | AT&T 1717 Digital Answering Machine
Vtech 5.8GHz Analog Cordless Phone Logo
159 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
