Question about Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony wega kv-36hs20 will not turn on
Red light is blinking seven times
    Genius:
  • 1,550 Answers
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Posted on Mar 02, 2009
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega tv blinks seven times and does not come on
seven blinks means high voltage shutdown it gone into safety mode you need to check power supply regulation and horizontal circuits
shaun
Jan 16, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Problems with Sony FD Trinitron WEGA KV-36HS20
The set is going in to the protect mode.
There are some components that have become thermo sensitive from age and use. After the defective parts come up to their operating temperature they go out of specs.
Most of the time this type of problem comes from the power supply. Sometimes it is from another board that is causing the shut down.
The fix is to start by replacing the power supply for a start. If there are still any faults, the tech will try the boards to zero in on the defective one. Once he locates the defective board, if it is not worth to service, he will leave the new board in the set.
This type of repair can be in the average range between $200 to the $500 range depending on the exact fault. This is providing that the fault is not inside of the screen itself.
Jerry G.
Jun 02, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony KV-36HS20
Jan 28, 2008 | Sony KV-35S45 35" TV
Sony FD Trinitron WEGA KV-36HS20 36" TV Logo
388 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
