Question about Sylvania 6626LG 26 in. LCD Television
HDMI input failure
I finally decided to upgrade my input to HDMI once my cable company got a new box that had HDMI out. When I hooked up the TV the HDMI input gave me only a black screen then after plugging it in and out a few times gave me a green screen. I know the box and cable work since I hooked up another TV and it worked fine. I called JVC and went through the whole HDMI reset without any luck. They said I need to get this serviced, but I really don't want to pay for this for a TV 3 yrs old, especially since it obviously never worked from the beginning (I just never used the HDMI input until today). How much would this cost me (or is there something I could replace or check myself for less money?) My HDMI input has worked fine for about 6 months, now all a sudden it does not. This TV is in my bedroom and is not used much. The only thing ever hooked up to is a HD dish network receiver. I know it's the TV's input because I tried hooking my PS3 up to this TV and got the same thing. (Is there a way to reset the input) I have tired unpluging everything for hours still no help.
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
Posted on Oct 29, 2008
  • 10 Answers
SOURCE: Comcast remote cannot operate Funai/Sylvania
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
Posted on Oct 19, 2009
gammaray1022
  • 30 Answers
SOURCE: trying to hook up HDMI to PS3 and the TV keeps
Try using another AV cable (like a normal composite cable) and try going through your PS3 setup. It may be that it is trying to go to 1080p or something because it is the HDMI, which wouldn't work on yours I bet. See if you can disable the higher resolutions and try the HDMI again to see if you can get the 720p to work. Hope this helps!
Posted on Oct 21, 2009
rahulwozniak
  • 87 Answers
SOURCE: TV powered off without warning and fails to power
the power needed by the TV is not being completely provided
Posted on Jan 13, 2010
I have a Sony Bravia led digital kdl32m4000 tv, I am upgrading my satellite box to hd will I get the signal in hi def. or do I need to upgrade my tv?
No you don't need a new tv. Hook up your HD cable box using HDMI cable. Hdmi out on your cable box then hdmi in on your tv. You need your tv remote to change source input to hdmi.
Jun 10, 2017 | Sony Televison & Video
How do you hook up cable box using coaxial in hdmi out
If your cable box has an HDMI OUT connector you simply connect the HDMI cable to the TV and the coaxial cable from the cable company to the coaxial input on the cable box. Then select the HDMI input on the TV that matches the number of the HDMI input port you chose on the back of the TV.
Mar 03, 2016 | Insignia NS-LCD32 LCD TV
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
I have a sony bravia KDL52V51000 and today it decides not to read the HDMI inputs. just says no signal. it recognizes that there is something plugged into my 3 and 4 inputs but when i click each of them...
1. Please try a new HDMI cable.
2. Try to upgrade the FIRMWARE of the TV. You may download it from SONY official website if there is a upgrade for your model.
3. After upgrade the firmware, if the problem is not solved, change the main board.
Aug 11, 2017 | Sony Bravia KDL52V5100 Compatible Swivel...
A new cable box was connected to my 32" Proscan LCD TV. Now everytime I turn on the television I see the message "HDMI-1 No program information available" I contacted the cable company and...
I know this may be a dumb question but I have to ask because even though the cable company has HD boxes a lot of them still dont have HDMI outputs instead they use the 5 Component cable (red,blue,green,for video and white, red for audio). Not only that most of the cable guys are not the brightest in the world I work in an electronics store for 13 years and cant tell you how many times I went to someone house and it was hooked up wrong. Are you stuck on HDMI-1 or can u chnge the channel by using the tv/video button it may say input as well. Check how its hooked up easy to tell 1 cable HDMI, 5 cables -Component. If it is HDMI check the other hdmi input as most LCD tvs have at least 2. same for component it will say component on screen
Dec 14, 2010 | Proscan Televison & Video
HDMI trouble: ''Your TV does not allow display of this program...
''Your TV does not allow display of this program through the DVI input source. Please choose another TV input source
whys it say that
Mar 19, 2010 | LG 32LG30 32 in. LCD HDTV
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
Hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Jan 29, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Dec 04, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Sylvania 6626LG 26 in. LCD Television Logo
101 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
