Question about Mitsubishi WS-65511 65" Rear Projection Television
Mitsubishi 65" model # ws-65511
Hi, I have a tv and it just went dead. When I plug it up I receive a steady flashing green blinking light. I have tried to use the reset system button but it still didn't work. The Tv is in good condition and it was showing fine before it went dead. Do you have any suggestions on the problem and possible fix. I have read some info on this problem and other eu's said that it might be the pwb or the DM. Not to sure if its a low end power board or the DM, Please help.
Thank You
  • Ahmose Avin
    Ahmose Avin Mar 12, 2009
    thank you so much. I got the seven capcitors and took the seven old capcitors out and put in the seven new capcitors. the TV blinked for about 60 seconds and the TV came right back up with no problems. thank You so much for your help and assistance.
  • Mitsubishi Master
  • 8,617 Answers
The steady green blinking led is due to the DM not completeing the boot Cycle. You can get the repair kit at the following link which contains the replacement Capacitors and step by step detailed instructions so you can do the repair yourself. Very inexspensive Kit
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Mar 02, 2009
  • Sonny Berry
    Sonny Berry Mar 12, 2009
    youre welcome glad that I could be of assistance to you.
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
I have a mitsubishi ms-65511 and we had a poweroutage for several hours today and now the tv won't turn on and I am getting a continuous green light of death ... HELP
Thats caused by weak capacitors on the DM board which cannot recharge after the power has been restored. Very inexpensive repair . The WS48511 - WS55511 DM repair kit from www.tvrepairworld.com has the capacitors and the CD with repair instructions which should solve the issue of the steady blinking green light.
Oct 11, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65511. Won't stay on.
Bad filters in the main microprocessor. good luck.
Aug 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
Aug 08, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Tv won't power on ws-65511
This forum is pretty dead. Anyways the technician came and disconnected the wires running to front control panel ( where the buttons are). And now the TV works with the remote. Apparently the front pannel had shorted.
Details: He moved the grill on top of the speakers. You will see two sets of wires running from the bottom of unit to the front control pannel. These wires are joined by clips. Just disjoin the wires at the clip.
Apr 18, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Help on Mitsubishi WS- 65513 65 in.
Look around online and find that this is a huge problem with Mitsubishi rear projection tv's. It is the board that needs replacing at $1100. My tv is 3 years old and already a big paperweight. Blinking green light of death.
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
473 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
