I have a CyberHome CH-DAV 415 home theater system, and it displays "NO DISC" when loading a DVD.
  • 3 more comments
  • vafcyn1111 Mar 02, 2009
    I have a CyberHome CH-DAV 415 Home Theater System that displays "NO DISC" when loading a video DVD. I have just run a cleaning CD without a successful result. It will play music CD's clearly.
    I have a CyberHome CH-DAV 415 Home Theater System that displays "NO DISC" when loading any video DVD. I have just run a cleaning CD without a successful result. It will play music CD's clearly. I have tried turning the unit off and back on, and have had no success.
    The recommendations for cleaning the lense of the laser has not yielded any better results.
    I have a CyberHome CH-DAV 415 Home Theater System that displays "NO DISC" when loading any video DVD. I have just run a cleaning CD without a successful result. It will play music CD's clearly. I have tried turning the unit off and back on, and have had no success. I ran the laser lense cleaner again, still no success. Any other suggestions?
    I have a CyberHome CH-DAV 415 Home Theater System that displays "NO DISC" when loading any video DVD. I have just run a cleaning CD without a successful result. It will play music CD's clearly. I have tried turning the unit off and back on, and have had no success. I just purchased this unit from a local Radio Shack dealer, but it was a floor model and I assume that they won't honor a manufacturer's warranty. Are there any other suggestions?
  • 1,800 Answers
Try reset the unit.
type rest in the manual here and leran how to rest the settings also checkout the parntal lock feature it
Posted on Mar 02, 2009
  • 15,935 Answers
Your laser is out of alignment. As suggested, if out of warranty - replace it. DVD players are pretty much dispensable these days. For $25, you can get a new one - or spend $40 (min) for repair.
Thanks for using FixYa!!
  • 6,487 Answers
This is already a sign of a lens that is getting bad, you can try to run again the cleaner and if it doesn't fix the problem you may want to consider replacing the lens of the player..
  • 2,336 Answers
Some of this devices have 2 lenses, one to play DVDs and the other one to play CDs; both are mounted on the same assembly. In this case the lens reading the info from the DVDs became defective if and will need to be repair by replacing the assembly. This type of repair is not economical if your device is not under manufacturers warranty.
  • Jaime Hernandez Mar 02, 2009
    I would still suggest to go back to the vendor and ask them to give you another one since this one is defective and they should know how to deal with the manufacturers.
    Good Luck.
  • 10,515 Answers
It seems that there is an issue with 'Lense"................
  Try to use a lense cleaner ....( Usually that happens when the lense is totally wear out, Or sometimes.....if you might not have used this for a long time )......
  If that would work it's great, unless you need to open it manually and need to clean the lense with a soft cotton or cloth .....
Thanks and Regards, Taran.
  • taran_2005
    taran_2005 Mar 02, 2009
    Make sure ..the CD that you are trying to run is not corrupted.
      If the CD is running fine on other system, than there is a need to troubleshoot your Home Theatre System.
     And also make sure the extension of the video file is compatible with your Home Theatre.Like mp4 and other codes are not compatible with most of the Home Theatre System.You might need to upgrade the firmware or you might need to look an alternative like change of video codes for the existing file...
    Thanks for using Fixya.
    Take care.
    Brigadier General:
  • 8,619 Answers
Hi!
Does this message displays every time you play a disk?
What type of disks are you using(DVD+RW,DVD-RW,etc)?
Try switching off and then on the unit.
    Scholar:
  • 165 Answers
It is because the lens is bit dirty.try cleaning the lens with lens cleaning cd or manually clean it by opening the device.it will be solved
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
Cyberhome chdvd 415 does not read dvd says no disc
That might be a problem with your len which it is very popular today, try cleaning you len with a lens cleaner cd.
Dec 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Sony 5 disc dvd player says c 31 00
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Mar 02, 2009 | Sony DAV-FX10 System
New Sony Bravia DAV HDX576WF disc lights flashing one by one
This is referred to as the demonstration mode. It is in your' manual on how to turn off this feature.
Feb 28, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD players not always beinvg able to load DVDs
You have bad filter caps in the power supply c10 and c11 need replaced and unplug unit when not using as power supply stays on always,,,,as long as its plugged in its on(P>S>) that is
Jan 02, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
