Question about HTC Touch P3452 Smartphone
Verizon xv 6900 wont boot up
I try to turn it on and it freezes when the verizon logo apears. I did all the resets possibe soft and hard. Still frezzes what can i do to fix this.
    President:
  • 1,223 Answers
Just go and upgrade ur ROM from www.htc.com
and tell me the results
Posted on Mar 02, 2009
  • Shoaib Rais
    Shoaib Rais Mar 02, 2009
    kindly also try to take out ur mini sd card and see if it still freeze pls tell me the results to get help
    pls do rate me fixya if i fixed ur problem
How do u reboot the htc one
If there's a problem with your screen or you're otherwise unable to do a factory reset via the settings menu, then you can use the hardware buttons to do a reset too. Simply turn your HTC One off, then press and hold the Volume Down and Power buttons. Continue to hold them until you enter the H Boot screen.Aug 23, 2014
How to hard reset the HTC One - AndroidPIT
https://www.androidpit.com/hard-reset-htc-one Feedback About this result
HTC One (Verizon Wireless) - Restarting HTC One (Soft reset ...
www.htc.com/us/support/htc-one-verizon-wireless/howto/394150.html
  1. Cached
  2. Similar
Restarting HTC One (Soft reset) If HTC One is running slower than normal, is unresponsive, or has an app that is not performing properly, try rebooting and see if that helps solve the problem. If the display is off, press the POWER button to turn it back on. Press and hold the POWER button, and then tap Restart.
HTC One - Resetting HTC One (Hard reset) - SETTINGS & SERVICES ...
www.htc.com/us/support/htc-one/howto/365649.html
  1. Cached
  2. Similar
Performing a factory reset from settings. Go to Settings, and then tap Backup & reset. Tap Reset phone. Tap OK.
How do reboot the htc one Google Search
Nov 08, 2016 | HTC Cell Phones
My phone is a Verizon Moto G , it sometimes freezes the apps, and then it turns off by itself. When I try turning it on it wont work, then i hold the power button and it vibrates, and take a while to
Panesha
Try running the phone in safe mode. To do this. Press power button then when power down appears. Long press power down option. It will ask if you want to boot into safe mode. Select ok the it will reboot in safe mode. Use the phone in safe mode for 24 he's to see how it works. If it works better, then there is a third party app you installed on the phone that I'd causing freezing.
Mark
Motorola Support
Nov 13, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
Droid 4 wont work after soft boot
I would perform a factory reset.
How do reset my DROID 4 to default settings
You may need to do option via external keys.
Mark
Motorola Support
Aug 01, 2014 | Motorola Mobility DROID 4 4G Mobile Phone...
Phone powers on to the verizon wireless screen and then the screen goes black for a second and then back to the verizon wireless screen. this continues without fail. did hard reset already.
try hooking into the PC and master reset, see link -->
www.verizon-phones.us/how-to-reset-verizon-samsung-reality-factory-default-settings
May 03, 2011 | Samsung Reality U820
I have a Verizon XV6900 or (htc) 6900 and all
Did you try plugging another charger or connecting it to your pc by usb cable if it shows charging its the power button
Dec 10, 2009 | Computers & Internet
LG enV2 wont get past the black screen with the verizon logo
put a battery on it turnit on off on offf,,,,,if not throw it away!!!!!!!!!!!!
May 31, 2009 | LG enV VX9900 Cellular Phone
Cant get my HTC 6900 to turn on to the main page.
You can simply try to hard reset your device. But before that, have you ever backed up your personal data? Because after a hard reset all your personal data will be erased, and your device will be factory resetted. Here's how you can perform a hard reset: Press and hold the red and green buttons at the same time while pressing the tip of your stylus in the reset hole and holding them in place until the gray screen comes up.
Apr 20, 2009 | HTC Touch P3452 Smartphone
Does not get past the Verizon screen when turning the phone on.
I hate to be the bearer of bad news but the only thing i would say try is taking the battery out for about 30 seconds. putting it back in and trying again. if it does not turn on then i'm afraid the phone will not come back. It's a somewhat rare problem but does happen.
Unfortunately all information is gone unless you had downloaded backup assistant.
Apr 13, 2009 | Samsung SCH-a870 Cellular Phone
Vx5300 Freezes
Here is the cure:
http://slashdown.wordpress.com/2008/02/05/fixing-lg-vx5300-freezing-problem/
Jan 07, 2008 | LG VX5300 Cellular Phone
It cant turn on
Just some suggestions. I have had my Q9m since September 07. If you reboot the phone nightly (take battery out put back) and allow to boot up again it help by resetting the RAM. Also under System Tools>Task Manager>Menu>Kill All - it seems that every program you use on the Q it keeps running which causes the Q to slow down and freeze. I know doing these things can be a pain however my Q has been running with zero issues since September. I also have the origional Q in black for over 16 months and I wouldnt trade either phone for anything on the market currently. As far as the screen sticking on the Verizon Logo...try taking battery out, power on and as soon as logo appears pull battery out quick and replace...you may need to do this a few times but it will bypass what ever is causing this boot up error. Windows Mobile 6 certainly isnt perfect. Hope these suggestions help.
Dec 11, 2007 | Motorola Mobility Q9m Smartphone
HTC Touch P3452 Smartphone Logo
169 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
