Question about Toshiba Satellite A135-S2276 Notebook
Ethernet cable connected not detecting
I called my service provider verizon fios went through all of their suggested troubleshooting checked the cable bridged the connection make sure router and cable was working updated all the ethernet drivers for my ethernet card and it says device is working properly but it's not detecting that the cable is plugged in need more trouble shooting tips i can connect wireless but not direct
  • jamesjackson Mar 02, 2009
    static ip address? and there is no light on i know the cable is good because i bridged the cable on the ports in my router and all lights say good device manager says the device is working properly just not picking up that the cable is plugged in
    yes the device in enabled and i checked whether or not it was static or dynamic they are set on automatic and the cable is a regular ethernet cable i have like 5 of them and i have tried all of them and they all get the same results i'm thinking that the ethernet card is no good but everything checks out and says it's working properly .......do you think if i bought an external usb to ethernet to connect to my router it would help i'm running at 54mb's right now with the ethernet i'm supposed to get 100+ mb's i think i will loose speed by going through the usb it might just be more trouble than it's worth.....any other suggestions on how to get this to work or troubleshoot some more if you want contact me direct through e mail make things a little faster JamesJackson11@verizon.net
  • 523 Answers
Make sure you donot have any static ip address in your network, or make sure you didnot disabled your network card, try to look in laptop network card if there is a linking light when you connect the cable? if not either cable or network card has problem.
try this and let me know what happen?
Best regards
Posted on Mar 02, 2009
  • Kyocera HP Expert Mar 02, 2009
    Did you checked if your network card is disabled?check this by hitting right click on my computer, select manage then go to device manager, look for the network cards if its disabled or enabled.
    Checking if the is static ip address in your computer: right click on my network place, then select properties, then select your local area connection and right click and hit properties,scroll down to internet protocol tcp/ip, double click on that see if your IP address and DNS server are automatically selected.
    you have to make sure from verizon wat ip you use, is it dynamic means automatic or static which means they give you ip address and you have to put in ur pc.
    Also try to know there is two types of cables, some of them are crossover cables which will not work with your network if you are using modem or router, you need regular ethernet cable. the only way to define that if you look for cable color pins how they are punched.
    Try this and let me know what happen
    Best Regards
Xfinity tv troubleshooting
Quick fix. Get rid of slow cable.
Go to Verizon FiOS if you can for the same services, but much faster and Verizon service is unparalleled.
I have DSL here where there is neither option.
Folks who have FiOS love it.
george
Aug 28, 2014 | Computers & Internet
Can I forward the calls on the cable phone to my cell phone?
Judy,
Without knowing who your cable phone provider is, I can't be sure. (My internet phone service provides call forwarding services, however each provider offers varying services for different fees.)
If I were you, I would contact my cable phone service provider to confirm your services. Your Motorola phone should be able to receive the forwarded calls just fine.
It's definitely worth checking into. I love the service!
Happy Communicating!
--Sandy
Apr 13, 2011 | Motorola Cell Phones
Xbox not connecting to router
call your internet service provider
Jul 13, 2010 | Microsoft Xbox 360 Console
Modem
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Apr 09, 2010 | D-Link DFM 562IS (DFM-562IS) Modem
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Jul 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I already have verizon internet"fios' how ever i want to purchas cable for my hd tv
Usually Verizon can offer HD TV over the same FIOS cable. If you call them, they can connect it to your TV for you.
If you call the cable company they can probably set up cable for you. The two shouldn't interfere with each other.
Jan 25, 2009 | Computers & Internet
To: Verizon Central Many Problems: Please help! I have Verizon Fios for my television and Internet. (1) I am unable to access the Internet online on my laptop. That's the first problem. (2)I have...
Verizon Fios Fiber Optic Television http://www22.verison.com/residentialhelp/
Verizon Internet and Verizon Wireless Internet
Verizon | Yahoo!
Verison | AOL
Verison | Live
Verison with MSN premium
Verison Online
Vonage Phone number suggests to me a that you have been sent a ( Router )
Check to see that your particular router supports wireless
If wireless is supported on your router you may wish to contact verison over the phone for farther instructions.
Selah :-)
Sep 14, 2008 | Computers & Internet
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Apr 09, 2008 | RCA F27625 27" TV
Toshiba Satellite A135-S2276 Notebook Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
