Question about Panasonic Televison & Video
Black box in center of screen when the source is on TV. No sound on Component 1 but no black box and when on HDMI, I have both a great picture and sound. Panasonic PT52LCX65 52 Inch 16:9 LCD Rear Projection HDTV
  • 27 Answers
Have you tried making sure that Closed Captioning is off?
Posted on Mar 02, 2009
Samsung flat-screen TV model LNR328WX/XAA has no picture. Sound is okay. I suspect the power supply board has failed, and would to confirm that, before I order a replacement board.
I would definitely check on the SOURCE button on your remote control, set accordingly first. EXAMPLE#1: HDMI (1) / HDMI (2) or (3) or (4) / Component inputs, EXAMPLE: GAMES LIKE A X-BOX / Check the Regular TV input. Good Luck.
Jul 05, 2017 | Samsung Televison & Video
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
I got a Emerson 50" on Black Friday! Wii on component input has no red in the picture.
Try another component video cable. It sounds like the red signal isn't getting to the TV.
Nov 29, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Screen is black. Can not see picture
if your connected with component cables then the GREEN connection is probably loose on wither the TV or the Cable BOX especially if you still get sound if its HDMI unplug both the cable box and TV from the power then reconnect the HDMI cable
Dec 03, 2010 | Protron PLTV3250 32 in. LCD Television
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have issues with my unit. Sync problems
Are you sure it's the TV and not the video source ? Have you tried other video sources ? You can also try to switch over to component cable. The red/green/blue colored cable. You only need HDMI for blu-ray to get the 1080p. If your TV is only 1080i then you don't even need to use HDMI. Also, some sources actually look better with a component cable compared to HDMI. Give it shot.
Mar 14, 2009 | Samsung LN52A550 LCD TV
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Black box in center of the screen?
could it possible be a problem with closed caption setting....is this a square or rectangular box how big?
Feb 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
