Question about HP DeskJet 3745 Printer
MY PAPER IS JAM IN MY HP DESKJET D4160 PRINTER
    Brigadier General:
  • HP Master
  • 3,614 Answers
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Posted on May 28, 2009
  • 67 Answers
Open the paper jam cover at the back of the printer and remove the jammed papers, be sure you return properly the cover afterwards. Re-start your machine.
Posted on Apr 28, 2009
4 Suggested Answers
manojro
  • 495 Answers
SOURCE: ip address of hp deskjet d4160 to add printer in network
For getting the IP address, first you have to check printer settings from printer LCD display panel. Or alternatively you can search for network connected printers and then install it.
Posted on Dec 02, 2008
BurntLime
  • 8 Answers
SOURCE: Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Posted on Jan 05, 2009
SOURCE: hp Deskjet F380 all in one printer gives messege paper Jam but...
Restart the spooler.
You have to do this even if it simply runs out of paper.
Its rubbish at sorting its self out.
It even complains you have no ink when you put in a full re-manufactured one!
Posted on Jan 20, 2009
Yellow light blinking and I cannot print
Most likely, the light that is blinking is the Resume light.
When this happens, you should check the following conditions:
The printer might be out of paper.
Place paper in the input tray, and then press the Resume button.
There might be a paper jam.
The printer cartridges are not installed correctly.
Mar 05, 2011 | HP Deskjet D4160 InkJet Photo Printer
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
Yellow arrow light keeps flashing, and the printer
That is a caution arrow, make sure you have paper loaded and that there is no paper jam.
Oct 30, 2017 | HP Deskjet D4160 InkJet Photo Printer
Hi HP deskjet d4160...runs the paper but prints either 1 line or nothing
It may need a new ink cartridge or the flat cable from the printer head is broken.
Dec 02, 2009 | HP Deskjet D4160 InkJet Photo Printer
Need software for hp desktop printer D4160
HP Deskjet D4160 Printer Basic Driver Installation Instructions:
1. Click on the Download Only button and a File Download box will appear.
http://www.nodevice.com/driver/Deskjet_D4160/get39222.html
Sep 10, 2009 | HP Deskjet D4160 InkJet Photo Printer
How to dislodge a paper jam
turn off your printer.
Carefully pull out the paper.
And run the printer.
Jul 11, 2009 | HP Deskjet D4160 InkJet Photo Printer
Flashing arrow light and printer won't print. Paper is in. Ink is properly in. cables are in. No paper jam.
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP Deskjet D4160 InkJet Photo Printer
HP DeskJet 3745 Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
