My computer will not initialize the scanner any more.
  • 564 Answers
  • Unplug the Scanner from the Computer.
  • Unistall the the Scanner Drivers from the device manager and the software from Add/Remove Programs.
  • Restart the computer and Reinstall the drivers from the website.
  • then connect the Scanner.
Hope this Helps!!! Dont forget to Rate my Response!!!
Thanks!!!
PREM
Posted on Mar 02, 2009
  • 61 Answers
You will need to go on the manufacturers website and download the driver for your model scanner. Install the driver and let me know what happens.
    Genius:
  • 1,550 Answers
Provide model details of the printer .
Connect the printer to your printer and check settings in control panel .
  • SAM ANDERSON Mar 02, 2009
    Connect the printer to your computer properly and check settings in control panel in printer and fax settings ..
  • 410 Answers
First chek to be sure your interface cable is connected properly (diconnect and reconnect both ends). if this doesnt fix it you may need to uninstall and reinstall the scanner software. that should get you back online. thanks peyton
How to enter the scanner SYMBOL MC9090 boot loader in the IPL (Initial Program loader). What you need to press or do to start downloading bootloader IPL.
you run IPL with a cold boot
  1. Press the primary battery release on the mobile computer to partially eject the battery from the mobile computer.
  2. On an MC9090-G, while the battery is partially released, simultaneously press and release the trigger and the Power button.
  3. Push the battery to fully re-insert it in the mobile computer. One audible click can be heard as the battery is fully inserted.
  4. The mobile computer initializes.
May 20, 2014 | Symbol MC9090 Barcode Scanner
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
Reset scanner
Please try this:
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
After installing the scanner I get a message that says "failure in initialization of scanner. Scanner is ofline or scanner power is off." I have checked all of the cables and the scanner is...
first most computers are plug and play, if yours is not then you need to load the software that came with the scanner, only then will the computer see the scanner
Mar 31, 2011 | Fujitsu fi-5120C
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
Initialized and cleared without being backed up
Initializing erases/deletes all user-programmed information and resets the scanner to its original factory settings - see page 83 of your owners manual. There is no backup function associated with the initialing procedure unless you have saved your data to a computer file or another scanner. You will need to re-enter your programming data.
Need the manual? You can download and print it, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
Bill B.
Listening in since the 60's
Feb 25, 2011 | Radio Shack Pro-95 Handheld Scanner
Computer says it cannot initialize the scanner
insert installation cd adn perform add a device. or if your pritner is connected to bluetooth it will not scan. as blue tooth signal is not strong enough to scan from pritner to computer. it works on some but don't work on all blue tooth
Dec 15, 2009 | HP Photosmart C5280 Printer
16 people viewed this question
jasbo
jasbo
