My cursor is frozen in the midle of screen wont move,and i used my mouse to move it..what i the solution pls
Which mouse are you using? Is it the integrated mouse or the USB mouse?
If you are using the USB mouse, then try checking if it's plugged in correctly.
If it's your integrated mouse, then restart the computer and when it's up. Try moving your mouse. Restarting it usually does the trick.
If restarting it won't fix the problem, then restart and boot to safe mode. While restarting, tap F8 until you see the options to boot to safe mode. Highlight safe mode by using the arrow keys and hit enter. When you are in safe mode, try moving your mouse. Works or not - update the mouse driver. You can use RadarSync. If no go, then you might need to do a system restore. If worse comes worst, do a complete operating system reinstallation.
I hope this helps!
David
SOURCE: Mouse cursor moving by itself
I have the same dell computer, you have to down load the newest synaptics driver and disable the touch point mouse in the middle of the keyboard.
Here is the link.
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&qmp=12&p=1&subcat=dyd%2f17&rf=all&nk=t&sort=-date&snpsd=A&ira=False&spf=Latitude&ssysid=LAT_PNT_P3C_C610&ssysn=C510+%2f+C610&~srd=False&ipsys=False&advsrch=False&~ck=anav
Hope this helps!
It worked for me.
SOURCE: how do you fix a frozen mouse for a acer aspire 5315-2077 laptop?
Fn F7 probably got pressed (turns on and off the trackpad. probably the dumbest thing to have a hotkey for)
SOURCE: Acer eeePC keyboard, usb mouse, trackpad frozen
you can do everything you can do with a mouse with a keyboard, you just have to know the shortcuts. try finding the shortcuts or buying a cheap mouse and trying that.
SOURCE: the mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
SOURCE: My Acer Aspire 4730z mouse pad is frozen
Hi there, Press FN+F7 key and use your mouse pad. Right now its on disable mode. Thanks.
