Question about Whirlpool LER5636P Electric Dryer
I have a whirlpool dryer that will tumble but makes a noise
It will dry but it makes a "rubber clicking" noise..gosh does that make since? almost like the wheel of fortune clicking noise ?
  • johnanddawnc Mar 02, 2009
    i opened it while it was tumbling and i think it has something to do with the drum? its not tumbling smoothly
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if perhaps something has fallen down the vent hole atop the dryer, it leads directly to the fan so its quite possibel to be making that noise, if you remove teh back of unit yo can locate the "channel " that the filter goes down and by removing a few screws yo can remove the channel to check for obstruction, the 2 screws undethe filter on top need to be removed as well. good luck!
Posted on Mar 02, 2009
  • Ron Coons
    Ron Coons Mar 02, 2009
    well in that case perhaps one of the rollers supporting the drum has gone outta round, or even a "screw" lodgedinto the front felt glide causing the "Bump"
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 13, 2010 | Maytag Dryers
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
GE Dryer makes deep sounds when hot and tumbling
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Whirlpool LER5636P Electric Dryer Logo
276 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
