Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Where do iget a ballast for a panasonic pt50lc14? already replaced bulb, looking for a ballast. is there a spacific ballast i need?
  • 37 Answers
My recomendation would be save your money, and spend it on a new tv. by the time you pay for it you could of bought yourself a new tv...even though it wouldn't be a 50" you'll be much happier in the long run.........
Posted on Mar 12, 2009
Panasonic PT-61DLX76-K TV, no picture, red lamp indicator flashes once every five seconds. Bulb looks okay visually. Panasonic says bad ballast I need confirmation and service manual.
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Dec 01, 2010 | Panasonic PT-61DLX76 Television
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PPT-50LC14
This points to a bad ballast and you need to have or replace this part. The ballast Pcb part number is LSEB3131A. This is the only solution given for this error code blink.
-Josh
Feb 08, 2008 | Televison & Video
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
770 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
