Question about Microsoft LifeCam NX-6000 Webcam
Initialization error desplay on lifecam window
Webcam will not start, it is conected but not recognized.When lifecam window is open it desplays " Initialization error" sign.Try uninstal it and instalit again but it is same as before. Karl
  • 8,637 Answers
Normal 0 Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work. Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype ( ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger ( ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Posted on Mar 20, 2009
After replacing a logic board on tallygenicom,it desplays the error "sucurity violation" how do i resolve that problem
Security lock was installed in the previous logic board remove the security lock and install it in the new logic board.
Feb 28, 2013 | TallyGenicom Office Equipment & Supplies
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Desplay not working, can I change the desplay and cost
Yeah you can replace it. I would suggest you to go to a mobile repairing shop and get repaired or you can to the service center. They'll charge you for the new display and for their service.
Good luck.
Thanks for using FixYa.
Jun 17, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Test your webcam here by hitting "Allow" in top window and assessing your webcam in left hand panel.
If it works here, you know the hardware is OK. Now you have to configure it to any program you want to use it in
SkypeIf you have problems when you use your webcam device in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your LifeCam device as the default microphone. For example, select Microsoft LifeCam VX-3000.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your LifeCam device as the default Webcam. For example, select Microsoft LifeCam VX-3000.
  7. Click Save.
  8. Test LifeCam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: (
I do not know the second program ( explorer express) but there will be a similar arrange for making your Hardware default
Aug 27, 2009 | Microsoft LifeCam VX-3000 Web Camera
VX-6000 is not recognized by Messenger or Windows Live
Have you tried to set up the webcam via yahoo or MSN. Go to the options menu and select webcam. It should ask you to select a device to use as your webcam. If it is available select your webcam and continue setup. You will have to do this with both yahoo and MSN
Jun 15, 2009 | Microsoft LifeCam VX-6000 Webcam
Jvc hr-dvs2
SO you actually got the S/VHS to capture via firewire into your computer? I can only get the DV side to work. I have the same unit with manual. I think your initial problem is a refresh rate, are you using Premiere? and can you make the viewing window smaller?
Nov 03, 2008 | JVC HR-DVS2 Mini DV/S-VHS VCR
Juke Screen Turn Off
the desplay pice was pulled in such a way that it broke the desplay cable conecting the main part of the phone to the screen. your options are to send it in to be fixed by a trained profesinal or to get a new phone. =(
Oct 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
LifeCam NX6000 Initialization Problem on Netvista
You need to get the update with Vista driver. so it will work with Vista.
Oct 20, 2008 | Microsoft LifeCam NX-6000 Webcam
You need to reinstall the software of the phone as its corrupted ,get it done if the phone is still under warranty or else get it done in a local mobile repair center ,do it on your own is risky in the process you may damage the phone permanently ............................
Good luck...
Sep 02, 2008 | Cell Phones
Microsoft LifeCam NX-6000 Webcam Logo
1,252 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
