Question about Toshiba 42HL67 42 in. LCD Television
Toshiba Regza only receives certain digital channels with antenna
My Toshiba Regza (42HL67) was receiving all local digital and analog channels in San Francisco over the air until the digital transition happened last week. Now it only receives two digital channels and a few remaining analog channels. I can't figure out what would have caused this. If it is receiving any digital channels, it seems that the antenna would be able to find all of them. What could have changed?
  • Anonymous Apr 20, 2009
    Are you not using a cable box? If not, I have found that with TW out here they constantly block or encrypt channels so that you need the darn cable box. I went from 15 or so digital channels down to 5 and they were only the local ones (NBC, CBS, ABC, FOX and PBS). HTH.
james klgr
  • 362 Answers
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Posted on Dec 14, 2007
SOURCE: 42hl67
make sure the power save setting is not on it turns the tv on slower > see if picture settings such as contrast and brightness are all the way up > or picture profiles are on right setting .e.g cinema is usually dark screen
Posted on Dec 07, 2008
  • 152 Answers
SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Posted on Dec 18, 2008
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
  • 87 Answers
SOURCE: QAM Tuner difference between Toshiba & Samsung
software upgrade available from toshiba.
Posted on Apr 24, 2009
What is the best converter box to use with toshiba regza 42hl67 flat screen tv?
As far as I can make out, this Toshiba model is made for the US market so doesn't actually have a freeview tuner. It will only receive satellite and cable HD signals and local US TV, all of which has to be bought. You need to get something like an August DVB400 - HD Freeview Set Top Box -Digital PVR Tuner with USB TV Recording, eBay would be best I think, where they are sold for under £30.00. The tuner packed up on my 32" Regza so I bought one of these and it works fine. Plus you can record to a USB stick if you don't want to miss a programme. Hope this helps ......BS
Feb 22, 2015 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 32hl67us -- I am attaching an indoor antenna to receive digital local channels, the tv will only search in analog.. Do I need a converter?
You don't need a converter. You would need one if you had an older Analog TV, to enable it to receive Digital over the air channels.
Check the manual to read about the various configuration sub menus. My TV is a Samsung and when I want to scan for channels, I can select AIR, CABLE, or AUTO. After I select AIR it goes on checking the spectrum, looking for DTVair and Air.
Nov 05, 2013 | Televison & Video
Sound on one channel from over the air antenna has suddenly become garbled. All others are fine.
If only one channel is affected it is not a problem usually with the set--it does not know what channel you are on---look in audio menu and make sure if set has SAP it is not on.
Nov 05, 2012 | Toshiba Regza 52XF550U 52 in. LCD HDTV
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with or for the direction of local transmitters. will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Toshiba 42HL67 42 in. LCD Television Logo
322 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
