Question about Ovens
How to change the fuse in my oven
I have a Whirlpool RBS245PDS Electric Single Oven (in wall) - after we ran the cleaning cycle it will not heat up now. I read on a previosly posted question that they fixed this problem by changing the fuse. Can you tell me where it is and how to get to it?
    President:
  • 2,651 Answers
Youll need to remove the unit form the cabinet and remove the back plate, its athermal fuse partnumber 9759243. not a glass type auto fuse. after yo uoredethepart it willbe easier to locate onthe back of unit. KILL THE POWER LIVE WIRES!!!
Posted on Mar 02, 2009
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
After self-cleaning, oven will not heat. I waited at least an hour before I tried to pre-heat the oven and it will not heat.
There is a thermal fuse on the back of the oven that has blown, it is in series with the broil and bake elements so when it goes out neither element will work. You will have to pull the oven and take the back off. the fuse will be behind the rear panel. It usually has to red wires going to it. Once the fuse is replaced the oven should work fine. It is fairly common for this fuse to blow during the clean cycle due to a lack of air flow around the oven.
Aug 28, 2011 | Whirlpool RBS245PDS Electric Single Oven
Not heating
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 01, 2010 | Whirlpool RBS245PDS Electric Single Oven
Oven wont heat
There is a temperature activated thermostat (TOD) that is located on the back of the oven that would explain the problem you are having. The part can be checked with an ohmmeter and should read 0 resistance if it is good. The part number is 9759243 if your model number in the description is accurate (RBS245PDS)
May 04, 2010 | Whirlpool RBS245PDS Electric Single Oven
After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
No power in heating elements
Check from your receptacle to the plug to the back of the oven. Then the wires that attach to the elements. Sounds like this is your problem. If this is not it, then you may have a bad board.
Dec 30, 2008 | Whirlpool RBS245PDS Electric Single Oven
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Aug 25, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
1,079 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
