Question about RCA P61960 61" Rear Projection Television
Tv tuns itself off, maybe needs bulb?
I am not sure, but I think the bulb went out. The tv would turn itself off and then back on. Now it won't turn back on.
  • autumnparks Mar 26, 2009
    I have the same model - RCA P61960 61 in. Rear Projection TV -- It will come on, play through the previews ... or about 10 minutes -- then just shut off. Later it will turn back on when prompted, play for a few moments and then just completely shuts off. Is there a special "emergency off" trigger that could be getting set for some reason? Please help!! aeparksmo@yahoo.com Thanks! Autumn Parks
  • Patrick Cowan
    Patrick Cowan May 11, 2010
    audio out too?
  • 4 Answers
Check fuse inside tv lower panel where power cord gose in to tv maybe your problem
Posted on Mar 02, 2009
Samsung HLR5667wx/xaa. Power surge took out tv. Replaced bulb and the bulb works, but tv wont come on and lamp light is flashing.
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Jul 10, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Fluttering sound when trying to tun set on, never comes on and shuts down. Sounds almost like a motorboat sound, but not quite. Recent bulb change. Made sure all vents and air filter were cleaned. Took the...
Maybe the fan is going out. Since you said bulb change I assume your tv is a projection tv. If so I think those tv's have fans to help keep it cool. If the fan is not working properly or failing, the tv may be shutting itself off so further damage does not occur. Check the fan. What is the model number of your tv?
Mar 08, 2010 | Hitachi 43FDX01B TV
LG DLP Suspected Faulty Bulb... how to be sure?
First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
Aug 06, 2009 | LG Televison & Video
Samsung 50" DLP TV turns itself off
I had the same problem which also included the picture having streaks of red in it sometimes too. I found that both problems were due to the TV getting too hot inside. I bought a $7 small 4" fan from Walmart and pointed it at the back "door" of the TV (where the bulb can be replaced). Both problems have disappeared which I think is due to not letting the interior get too hot.
Not sure if there is an internal fan to cool the parts inside, but if there is it is not working well enough.
Jun 11, 2009 | Samsung DLP HL-P5663W 56" TV
Smells like it is hot or something is burning after changing bulb
Your tv is actually an Air eater. The tv itself needs a complete river of air (it looks as an exageretion) not really. I create this picture in your mind to help you to imagine all care you tv needs.
  1. Turn off the set. allow 20 minutes to cool down the set
  2. move the tv to the front and get access to the back of the tv then with a vacuum cleaner gets all dust out around the set
  3. make sure the air filter (refer to the manual) is clean.
  4. try to make sure the places were the air flows into the tv are clean and free of obstructions (back cover).
  5. finally all you can do outside the tv is done. Then when the tv is back its position make sure it "breathes" confortable. You tv has 3 fans inside (there is not a casualty)
The fresh air that goes into the system gets finally out really hot and smelly but as soon as the air flows thats normal for this tv. this is noticiable specially in hot seasons.
Apr 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
RCA P61960 61" Rear Projection Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
